Queen bee scoping out her hive.
Unfortunately I didn't get more better pictures. It is basically a wood bolt with the head ground round then a nut chucked up on it for more body and the wing base. The wings are utensil ends that fit the bill. The legs and antennae are finish nails cut to length. Mig weld blobs for the eyes and mouth area.
I plan to make some more and will get more and better pictures then.
I used to do stuff like that with my stick welder, I'd turn it down really low, disconnect the ground clamp, hold the wire, nail, etc. with the stinger and pull the ground onto the table by the cable. Worked about 3/5 of the time. By work I mean it actually welded rather than just stuck and broke when disturbed. If you have paste soldering flux it's almost 100%
