Mild steel drilled balls
I am looking for mild steel drilled balls Ø3/4", with a smooth hole (not threaded) Ø3/8".
I live in Québec. I traveled the Internet and only found some (I think) in exotic places. Anything in Canada, in the US some of you would know about?
Thanks.
I have an Indital USA catalog from several years ago that has "Hot Stamped and Forged steel Spheres" from 20mm to 100 mm; I saw that there was a Canadian distributer  wayfair.ca that may have similar items.  Indital sells Italian forged ornamental iron items for welding onto fab work.
Thomas,
Thanks.
I have a project I will tackle after firewood season, a balustrade and I would like to use some steel balls in the joinery.
Try King Architectural Metals.  They seem to have a selection of various diameter balls.  I'd be surprised if they did not ship to Canada.
George,
I have been on their site. They do not have the dimensions I am looking for.  They have a ¾" Ø steel ball but only with a hole half thru.
I thank you (1) for the info and (2)… you got me thinking… I might think of using cubes instead of balls. I'll try this when I get to the forge.
The are simple to forge over the edge of the anvil with your hammer,,, and great practice.
Good Morning,
You can make a ball Spring Swage, or you can purchase one from from the regular suppliers of Blacksmith Tools. I have one that Grant Sarver made, bless his soul, he is now on the other side for 10 years. If you don't have access to a Power hammer or a Press, cut blocks and forge them round. Or, you get access to a Lathe and  make as many as you would like. CNC Machining???? How many do you need, 10 or 1,000.
Neil
8 hours ago, swedefiddle said:
Good Morning,
Neil
I do not know yet. Still in design process.
Neil, thank you for the input.
