Callebs Creek Cutlery Posted June 3, 2022 Share Posted June 3, 2022 I'm having trouble tuning the flame on this new ribbon burner forge. The first time I lit it, I got a large flame coming from the door and then a boom when I adjusted the gas. Is the door possibly too small? I'm worried that I might've created a bomb. Quote Link to comment Share on other sites More sharing options...
M.J.Lampert Posted June 3, 2022 Share Posted June 3, 2022 try using some notebook paper inside light the paper then turn on the burner if i take to long to long to light my T-burner i get a large amount of propane vapor in the air and this can cause a loud sound as it ignites. I have no experience with forced air or ribbon burners but it might light easier if you reduce air flow ?? others who know more will probably come by and provide a better opinion but that gives you a start point M.J.Lampert Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 3, 2022 Share Posted June 3, 2022 Turn down the propane pressure and start the flame with the blower off and then increase the blower and the propane alternating till you get the burn you want! And yes the flame will be yellow before the air starts up. You want the flame correct at the end of lighting and adjusting, not the start. The blown burner at the University had a 3' dragon's breath and nobody wanted to use it. They had marked the regulator body to show the correct setting for the handle. I backed the regulator off 3 complete turns and had the "correct" setting lined up again and a usable forge. Learn to tune by eye and ear and NEVER worry about gauges! Quote Link to comment Share on other sites More sharing options...
Callebs Creek Cutlery Posted June 4, 2022 Author Share Posted June 4, 2022 Update, Order of operation is key! I compare it to lighting an oxyacetylene torch. Straight fuel to start and then add the air. I got a little worried when I shut it down after the first real heat and I could hear the remnants of wax for the crayons sizzling out of the burner. Overall a fun build! I'm considering adding a PID and solenoid valve for heat control. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 4, 2022 Share Posted June 4, 2022 With a pass through (back door) so longer stock can be worked, I don't think it is a bomb but a good looking build. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 4, 2022 Share Posted June 4, 2022 It'll just take a little getting used to, I don't see anything wrong with your build or it in operation. All the wax will burn out before long. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
bubba682 Posted June 4, 2022 Share Posted June 4, 2022 I had the same blower when i first built mine i had to upgrade to more cfm's for better control not sayin its your problem but it was mine...Our forges look pretty cloase except i didn't paint mine i went to a bigger green blower 135 cfms i beleave it made a big differance. Quote Link to comment Share on other sites More sharing options...
Callebs Creek Cutlery Posted June 5, 2022 Author Share Posted June 5, 2022 Thanks for your kind words! Quote Link to comment Share on other sites More sharing options...
