The lathe in my shop.
A 1911 vintage 16” lathe. Tight as the day it was built, not a bearing in it.
Edited by Mod30
Resize photo
Perhaps you meant ball bearings?  I'm sure it has a bunch of bearings!  What does the head stock use?
Lol, yup has lead Babbitt bearings. What do you mean by what does the head stock use? Do you mean tail stock? 3 Morse taper.
I meant there had to be something spinning in the headstock and that means there has to be a bearing in it.  Babbitt makes for some good bearings that can be replaced in the workshop without resorting to a dealer in obsolete parts and gold bullion---(you bring them gold bullion, they will give you obsolete parts...)
The head stock has a Babbitt bearing. I should know, I poured it lol. Took 3 attempts to get the heat right and not have either a porous bearing or lead squirting all over the place. There are no ball bearings in this machine at all.
Exactly: thus my cognitive dissidence between:
"Tight as the day it was built, not a bearing in it."  and "The head stock has a Babbitt bearing."
Edited by Mod30
Resize photos
Just a note, you need to resize your pictures, they took a long time to load and I have high speed satellite internet. I pity the folks who still have dial up or pay for data.
I used to have one. It is still alive in a friends basement workshop. You can mount a vise like thing on the carriage and turn it into a milling machine, etc......
Neil
Neil
Yup, a milling attachment. Got one for it too. used it to cut keyways. I'll post it in a bit. First need to learn how to down size my photos.
Downsizing pictures is easy, once you click to add the uploaded picture, double click on it and an image box pops up showing the size. I use 500 for the first size and check the box for keeping the original aspect ratio, hit tab and hit update. If within the 30 min edit time you can also edit and double click on the picture to change it.
897412C0-EAEA-474A-90BA-8154A3313AF3.thumb.jpeg.87139a17c08f4507b53d3975d9036647.jpegI’ll give it a try. How did this picture come out?
Jim
9 hours ago, ThomasPowers said:
Looks good to me.
OK. Thanks for the heads up.
Jim
Cool lathe, but not sure about the hanging chuck setup. My chucks have always been stored on a cart or a bench. I would either drop one of those on my foot or hit my head on one.:D
  *drumming fingers*....
  Juuusst kidding....  Still, if you get time, it would be fun to look at!
Edited by Nodebt
Insert punctuation
Got tired of stubbing my toes on them laying on the floor. I go barefooted most of the warmer part of the year.
  Juuusst kidding....  Still if you get time, it would be fun to look at!
Oh crap, forgot. Will get that pic in a few. Again. lol
Jim
  Take your time... I wouldn't want you get in a rush and stub you toe.  You must have tough feet!  :)
Go all summer without shoes unless I have to go to work or some business. But home, hardly ever. Sometimes running a torch... hahaha!
We have goat heads everywhere out here; I've learned to slip on slippers just to go from the bed to the bathroom in the middle of the night.
  Slag makes short work out of toe jambs!
  Thanks for the photos.  Nice.  I'll look at them for a while before asking a dumb question or two.  It appears to me it clamps to the ways.  I have one my grandpa made himself, but it clamps in the compound rest.  Again thanks for posting the pix.
  Thomas, what are goats heads?  In the middle of the night?
I used to turn a lot of 4140 in my shop and I would not want to be anywhere near that lathe with barefeet and blue chips coming off all over the place. Not only will they burn you, but they are sharp as a knife. I had to spend 5 minutes picking them out of my work boots at the end of the day, wouldn't want to do that with barefeet. LOL! :D
