aparadi Posted January 13 Share Posted January 13 Hi all. I made my first knife and it's "OK". I have limited tools (no welding options, no taps for threading, no lathe, no drill press). I went with a hidden tang approach but wanted to have a separate piece for the guard. I was struggling with getting the handle on there tight enough to keep the guard nice and tight though. The slot I filed in the guard was a little looser than I would have wanted and allows for some 'wiggle' along the long axis. I figured that the flat top of the handle pressing against it would prevent that wiggle. I used steel 'rivets' for a mechanical bind - and it was really tight when I was hammering them in during the glue-up. But a couple of weeks later the guard has started to wiggle ever so slightly again. It is just not feasible to build a rock solid guard the way I tried to do it? Quote Link to post Share on other sites
Davor Posted January 13 Share Posted January 13 With a hidden tang you don't need to use rivets. Just use a good glue, two components glue is rock hard when dry, use a leather spacer between the guard and handle and you need a way to clamp it together till it dries. Couple of long bolts and two wood boards will do the trick. I haven't made knifes in a long time but I have made a few and you don't need fancy equipment to do them. First leather I used was from an old shoe, the one in the picture is from a coil spring, coin, leather, horn, leather and a piece of oak. Leather spacers help to hide the imperfections. Quote Link to post Share on other sites
ThomasPowers Posted January 13 Share Posted January 13 What was your grip made from? Did you bed it in epoxy? Tis the season in most of North America for wood to shrink. (Unless it was stabilized). Quote Link to post Share on other sites
aparadi Posted January 13 Author Share Posted January 13 Thanks for the ideas! I did use epoxy all inside the hidden tang and between the wood and copper spacer, but none between the spacer and the guard. I also didn't clamp it lengthwise while gluing it - I assumed the pins would hold it well enough (they were hard enough to get in!) I used very old oak that's been sitting in a garage for 30 years or so for the handle. Just used boiled linseed oil on it. Given how dry the wood would have been I would think it's more likely to expand than contract? Quote Link to post Share on other sites
ThomasPowers Posted January 13 Share Posted January 13 Depends on the environment, a home running a furnace can be drier than a garage. I also know that furniture found in the tomb of Tutankhamun still shows expansion and contraction with humidity changes and it's slightly older than "very old oak". To deal with guards some knifemakers will low temp silver bearing solder them in place. Here in the USA Stay brite is a common product. Most knife making books will go into the details of how to do this without messing up the temper of the blade. Also have you tried to snug up a gap by using a prick punch around it on the non-showing side? You can even see evidence of this being done on some Japanese sword fittings. Quote Link to post Share on other sites
aparadi Posted January 13 Author Share Posted January 13 Thanks for the idea Thomas - I'll keep that in my back pocket for the next time I mess up a fitting! Good point about the 'old' oak Quote Link to post Share on other sites
ThomasPowers Posted January 13 Share Posted January 13 I live in an area where single digit humidity's outdoors are common; when we buy kiln dried wood it's best to let it sit for a year or two to adjust to local conditions. Hammer handles really need "aging" before use. (The piano at our church has it's own dedicated humidifier inside it!) I moved here from a "damper" location and ended up re-seating 100 handled tools. OTOH we don't have the swing I used to get in Ohio from damp summer to dry winter. Quote Link to post Share on other sites
Frosty Posted January 14 Share Posted January 14 Wood is stabilized to prevent humidity causing dimension changes and loosening scales. Frosty The Lucky. Quote Link to post Share on other sites
aparadi Posted January 14 Author Share Posted January 14 Thanks Frosty! I'll look up what products are good for stabilizing the wood. BTW - I have plans to make one of your burners sometime soon! Quote Link to post Share on other sites
Davor Posted January 14 Share Posted January 14 Soak your handles in the linseed oil, at least a whole day. In the pictures is a knife I made about six or seven years ago and it didn’t shrink a bit. I soak it in linseed oil and then I polish it with bees wax. It is interesting because it is cut across the grain and not with the grain. Just wood from the shed maybe dried for a year possibly less. Quote Link to post Share on other sites
pnut Posted January 14 Share Posted January 14 On 1/13/2021 at 4:00 PM, ThomasPowers said: Also have you tried to snug up a gap by using a prick punch around it on the non-showing side? Are you talking about using the punch to push a small amount of the guard material into the gap? Just making sure I'm understanding correctly. Pnut Quote Link to post Share on other sites
aparadi Posted January 14 Author Share Posted January 14 Nice! Thanks for the tip. I have linseed oil, so I can try that! Quote Link to post Share on other sites
ThomasPowers Posted January 14 Share Posted January 14 Pnut, yes. Turns out that centuries ago fit and finish tended to be less precise and a lot more "cheating" went on. A swordmaker I know of mentioned that he wouldn't be able to sell swords made to medieval specs as even very fancy ones indeed tended to have mis-matched grinds, and other no-no's of modern blademaking. Quote Link to post Share on other sites
pnut Posted January 15 Share Posted January 15 That's a good trick to know. I'll keep that one in my back pocket until I need it. Thanks. Pnut Quote Link to post Share on other sites
