ACJ Posted November 26, 2020 Share Posted November 26, 2020 I've been searching every were, but I've never seen an automotive starter and ring gear used to power a hammer. Maybe the 200amp DC Tig welder I already have might power the starter motor and the 20ish to 1 ring gear reduction to spin in the 200 -400rpm range? Automotive starters have an over run clutch, that would be handy and It's dirt cheap compared to other options Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted November 26, 2020 Share Posted November 26, 2020 Good Morning AJ, Welcome to our world. You should add some information in your Avatar. There might be someone closer to you than the keyboard. A starter Motor is made for intermittent service, it will overheat if operated continually. I used a gear reduction starter motor when I made a hydraulic power-pak to operate the cylinders that open the side doors for our Portable Forge, 2 Doors, 17' long, 6' high, hinged at the top. The side provides cover if it is Sunny or Rainy (Mother Nature). It has only lasted 22 years so far.......... Neil Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 26, 2020 Share Posted November 26, 2020 I bought the like new 1.75 HP TEFC electric motor to run my 25# LG powerhammer for US$10 at the scrapyard. I expect it will last longer than I will and only need a 110 or 220 outlet. You sure that would be cheaper and easier? The cast iron pulley was 20 UScents a pound. Quote Link to comment Share on other sites More sharing options...
ACJ Posted November 26, 2020 Author Share Posted November 26, 2020 I'll add info to my avatar once I figure out how. I'm retired and like to build stuff using material from my scrap pile. My right elbow and left thumb are no longer usable for smashing iron. I'm located in N.E. Arkansas and will post some pictures of my forge, grinders and other homemade metal working tools. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 26, 2020 Share Posted November 26, 2020 Welcome; I'm from NW AR, born while my father was at UofAR in Fayetteville; got a degree from there myself and still have 13 acres of family land in Cedarville. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 26, 2020 Share Posted November 26, 2020 23 minutes ago, ACJ said: I figure out how. Click on your profile, select edit profile, there you can add location and other stuff. To add an avatar picture look at the big A in the circle, there is a box to add a picture there. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted November 26, 2020 Share Posted November 26, 2020 I agree with Swedefiddle that the starter motor would likely overheat and burn out with continual use. If you can attempt it safely tho, it's only a waste of time and materials if it fails, since it is already in your scrap pile. Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 26, 2020 Share Posted November 26, 2020 Welcome aboard, glad to have you. Just because you have something doesn't mean you HAVE to use it. Starter motors don't do well cranking for very long. One might last in a power hammer if you used an on off switch and let it cool while the steel is heating up. Maybe aim a fan at it. AC and DC motors are common often free for hauling off an unwanted hot tub. Old treadmills are another source but I don't like the circuitry to run a DC motor under a speed control and diodes to convert AC to DC. It's not hard it just adds another failure mode. Once I put the word out, I was gifted with two 3hp. 220v AC motors and pulled another out of the hot tub we tossed off the back deck. The most expense I suffered was the labor and $15 charge at the dump for the carcasses. Frosty the Lucky Quote Link to comment Share on other sites More sharing options...
