March 12, 20206 yr 16 hours ago, Nathan Kraft said: Also, I remember that I am supposed to have round, not square, plunge lines. But I’m not sure how to do that? Chainsaw files work fairly well for this. I mark the cutting edge of the blade for the thickness I want before heat treat and the bevel height I want on the blade. I then cut in the plunge lines on both sides with the chainsaw file using those marks to tell me when to stop. Now I have a good guide for the rest of the blade geometry. Hope that makes sense to you.
March 12, 20206 yr I've done this too; in fact, I think I may have gotten the idea from Buzzkill in the first place. Works well.
March 13, 20206 yr Author I’m almost to the point of pre heat treat sanding. Where do y’all get your sandpaper (I’m pretty low budget so cheaper options are better).
March 13, 20206 yr I tend to stock up on name brand paper when I can find them at fleamarkets and freight salvage stores. Cheap abrasives are generally not worth buying. Auto supply places may stock higher grits.
March 13, 20206 yr Author UPDATE: I have finished my bevel on both sides to the point of being ready for heat treat. I would fire up my forge and do the ht, but it’s a jabod and it’s raining outside (this would be my first time lighting my forge too) so I’m going to wait until tomorrow.
March 14, 20206 yr I've made a couple of knives using blanks, or the stock removal methods... yet to forge my own blade. But have alot of woodworking experience. A good hardwood that I really like is rosewood. It's a very tight grained wood with a reddish hue. Takes oil, varnish etc... well, or I have even left it plain and polished it with a clean buffing wheel. Not a high contrast grain though. Zebra wood is a good high contrast grained candidate. It has dark running lines through a yellowish/tan body. Works well, sands and finishes nicely too.
March 21, 20206 yr Author UPDATE: Over the course of the week, I have finished my knife. During the heat treat I melted the tip off (this was my first time lighting my forge and I wasn’t sure where the hot spot was). I ran and grabbed my anvil, and did my first ever forging putting in a rough tip. I then regroups it to shape. I opted not to do a high grit finish (I’m pretty Rough on my knives so it would be scratched up anyway). I used some scrap 1x4 for my handle and finished it with a burned oil finish (idk if that’s what it’s called lol). I have a pretty steep blade angle, and was unable to get to to shaving sharp, but it will roughly push cut paper. I messed up the handle as I forgot to profile the front of the scales before I epoxied it, but I was able to carve it down to a usable shape.
