philip in china Posted July 23, 2008 Share Posted July 23, 2008 I want some forks to fit on the front bucket of a small tractor. Is it possible to make them or would I be better advised to buy some? If I can make them does anybody have any tips? On a separate point what grade of steel would make good teeth ror the bucket? I can bolt teeth on but am not sure quite how to make them other than they will have to be harder than a mother in law's heart. Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted July 23, 2008 Share Posted July 23, 2008 Philip I built some for a mitsubishi 15 hp 3/8 X3 Flat bar with 1X1 CR teeth. 4 holes in bucket teeth welded to FB. Add on forks were 3in channel tapered tips with skid plates. Rear uprights to top of bucket with a hinge pin setup. forks 1 in below bucket edge. Use as wide a rear track as possible. I used a 400lb weight bar and loaded tires. Make sure to add a sub frame to the rear end. Mine cracked the block at the bellhousing. 1000lbs on the front. OOPS Ken Quote Link to comment Share on other sites More sharing options...
the_sandy_creek_forge Posted July 23, 2008 Share Posted July 23, 2008 Phillip, What are you planning on using the forks for? Also, could ya throw in a few details on the tractor, or a picture maybe? My thoughts on the teeth would be recycled truck axles or recycled jackhammer bits (big jackhammer bits ) -Aaron @ the SCF Quote Link to comment Share on other sites More sharing options...
welder19 Posted July 23, 2008 Share Posted July 23, 2008 In my opinion if your going to be lifting much weight or lifting it very high and or around people where, if the forks were to fail, someone could be hurt or your cargo or equipment damaged then I would say you would definitely better off to buy the forks, they aren’t cheap but neither are accidents, especially when lives are at stake. welder19 Quote Link to comment Share on other sites More sharing options...
welder19 Posted July 23, 2008 Share Posted July 23, 2008 In my opinion if your going to be lifting much weight or lifting it very high and or around people where, if the forks were to fail, someone could be hurt or your cargo or equipment damaged then I would say you would definitely better off to buy the forks, they aren Quote Link to comment Share on other sites More sharing options...
Dale Russell Posted July 23, 2008 Share Posted July 23, 2008 Philip , most ag equipment places sell forklift attachements that'll fit straight onto the bucket of your tractor , should also have the " bolt on rip teeth " your after too Dale Russell Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 23, 2008 Share Posted July 23, 2008 Some of the commercial tines are medium carbon steels like 1050 or 4140; kind of expensive in large chunks! The teeth are often hard faced to make them more wear resistant and so the alloy is chosen to make them easy to weld to. Earthquake clean up tools? Quote Link to comment Share on other sites More sharing options...
philip in china Posted July 24, 2008 Author Share Posted July 24, 2008 Not earthquake clean up tools. They have so much plant and equipment here I am amazed. I didn't know there were this many loading shovels in the world! These are for the place in Bulgaria. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 24, 2008 Share Posted July 24, 2008 Those jet-setting blacksmiths; can't keep track of where they are at today! Quote Link to comment Share on other sites More sharing options...
ironrosefarms Posted July 25, 2008 Share Posted July 25, 2008 If you dig the hole I will drop them down to ya, Indiana to China should be a pretty straight shot going straight through the earth... I have one set for attatching to a bucket and a set off a standard warehouse type fork truck. I plan to use the more standard set in the shop as something to hammer on = "long anvil", the set to go on a bucket are for sale... Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted July 25, 2008 Share Posted July 25, 2008 Steel recycling yards frequently have used forklift tines. Also, I've seen them sold on eBay. Quote Link to comment Share on other sites More sharing options...
