Kacy8261 Posted July 13, 2019 Share Posted July 13, 2019 Hello, I received this anvil and would like to know more about who made it, it’s age, the concave bottom and how the maker got it to ring like it does! Someone told me to drop a ball bearing on face in different places and see what kind of rebound it has.. It bounces almost back up to my hand! Maybe 85-90% of the way. Any info would be greatly appreciated. Thank you, Kacy8261 Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 13, 2019 Share Posted July 13, 2019 Knowing where in the world you are located may help. Hence the suggestion to edit your profile to show it. READ THIS FIRST I think it's a Swedish North Star anvil 130 pounds. https://www.iforgeiron.com/topic/48016-swedish-star/ Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 14, 2019 Share Posted July 14, 2019 Welcome aboard Kacy, glad to have you. If you'll put your general location in the header you might be surprised how many members live within visiting distance. It's cast Swedish steel and will do damage to your ears so get GOOD hearing protection. It rings like that because it's homogeneous high carbon vanadium steel throughout so it resonates like a bell. I have a cast Swedish anvil and mounting it on a steel tripod stand quietened it nicely. Good score, congratulations. Once you've used that beauty nothing else will do, not even a Mousehole. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted July 14, 2019 Share Posted July 14, 2019 Kohlswa anvil made in Sweden. Great anvil, but susceptible to edge chipping due to the hardness of the top. Only hit hot steel,and don't hit the edges with the hammer alone. Quote Link to comment Share on other sites More sharing options...
Kacy8261 Posted July 15, 2019 Author Share Posted July 15, 2019 On 7/13/2019 at 6:56 PM, Irondragon Forge & Clay said: Knowing where in the world you are located may help. Hence the suggestion to edit your profile to show it. READ THIS FIRST I think it's a Swedish North Star anvil 130 pounds. https://www.iforgeiron.com/topic/48016-swedish-star/ Thank you very much for your reply! I have edited my location and attempted to add a profile pic but I need to reduce size of file first. I also looked at the “Read this First” as well. I will attempt to comply with the rules set forth in said document. On 7/14/2019 at 2:17 AM, Frosty said: Welcome aboard Kacy, glad to have you. If you'll put your general location in the header you might be surprised how many members live within visiting distance. It's cast Swedish steel and will do damage to your ears so get GOOD hearing protection. It rings like that because it's homogeneous high carbon vanadium steel throughout so it resonates like a bell. I have a cast Swedish anvil and mounting it on a steel tripod stand quietened it nicely. Good score, congratulations. Once you've used that beauty nothing else will do, not even a Mousehole. Frosty The Lucky. Thank you very much for your reply & information regarding my posted question. i have edited my location . 23 hours ago, BIGGUNDOCTOR said: Kohlswa anvil made in Sweden. Great anvil, but susceptible to edge chipping due to the hardness of the top. Only hit hot steel,and don't hit the edges with the hammer alone. Thank you very much for the information! Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 15, 2019 Share Posted July 15, 2019 You're welcome Kacy, it's our pleasure. You don't need to thank us individually, we're not that formal a bunch, the occasional "thanks everybody" is plenty good enough. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 15, 2019 Share Posted July 15, 2019 On 7/13/2019 at 5:44 PM, Kacy8261 said: how the maker got it to ring like it does! You're welcome Kacy. It was pure luck that I remembered the star as a Swedish makers mark, Forgot it was used by Kohlswa. You have a premier anvil to say the least. They ring so loudly because they are cast steel and a lot of us have found out to quiet the ring, is to set the anvil with cheap latex calking compound between the base and anvil stand. Doing that will tone it down but not effect the rebound at all. Quote Link to comment Share on other sites More sharing options...
Kacy8261 Posted July 16, 2019 Author Share Posted July 16, 2019 Sorry for the multiple replies. I’ve always tried to be punctual, try to figure it out for myself first before bothering someone else & when receiving help from someone to make sure to always thank them & try to return the favor. Kacy8261 Quote Link to comment Share on other sites More sharing options...
Steve Shimanek Posted July 16, 2019 Share Posted July 16, 2019 I have a Swedish North Star 165 lb anvil also; I had to repair a lateral crack and edges with hard facing wire, but it is still a good anvil. Logo looks like yours. Quote Link to comment Share on other sites More sharing options...
