3rd real knife
Colluded with my wood worker brother on this one. Coil spring quenched in oil and 2 hours in the toaster oven. Tang is too small but my bro did a good job making the handle  comfortable. Fun to make we want to do more !
Looking good.  I don't see anything wrong with the size of the tang.  I prefer the tang to have a distal taper if possible.  Kudos to you both for the clean joint between the front of the handle and the integral guard/ricasso section.
The one main area I see for improvement is in your plunge grind.  I'd like to see it crisped up quite a bit, symmetrical on both sides of the blade, and set a bit further back towards the handle.  Of course these suggestions are mostly just aesthetic and meant to achieve some conformity with standard knives of this size.  The last will give you more cutting edge for your knife and get rid of some of that "wasted" front of the ricasso, but in the end you have a good working petty knife there.  The pins are particularly well executed.  Did you use Corby bolts?
45 minutes ago, Rojo Pedro said:
Tang is too small
Really? I didn't notice that. It looks like a nice, comfortable handle to me.
Mr. R. Pedro,
 What kind of wood is the knife handle made from?
Zebra wood?
SLAG.
I like it. good looking knife.
Thanks fellas
Latticino - appreciate the input. Not sure what you mean by distal taper in the tang. From top to bottom or taper lengthwise?
Mr. slag - “highly figured leopard wood”. Brother makes frames and it was scrap. He keeps asking for more knives to handle
Mr. R. Pedro,
Thank you for the wood I. D.
SLAG.
Distal taper is a lengthwise taper.  Your second photo appears to show that, but could just be parallax.  As I mentioned earlier, I think that is a good feature.
Isn't it technically a proximal taper if it is on the tang? (not sharp-shooting you, genuinely asking to make sure I am not misunderstanding terminology).
Nice knife, OP. I really like the handle shape.
I am putting the finishing touches on my first integral bolster knife - it presents a whole new set of challenges.
No idea.  Never heard of proximal taper being used in knife terminology. Makes sense only if you view a knife as having particular directionality, I  guess, which arguably blades have.  Sure, why not.
I believe it is correct to say "distal taper" as its a reference from end to middle. Very nice knife IMHO. :)
