jester Posted April 12, 2019 Posted April 12, 2019 Greetings all. This may be a stupid question to some, but I've just started using a gas forge again. And it seems the flames/blast comes a fair way out of the forge mouth. Ill attach some pics as soon as I can. ive tuned it to sound like a jet engine and she sure does get hot... but yeah, I can see a lot more outward hotness than I though got was normal. thanks in advance Colin Quote
Frosty Posted April 12, 2019 Posted April 12, 2019 Welcome aboard Colin, glad to have you. We call that "Dragon's breath" and yes your forge is producing more than is good. Once the forge is up to temp turn the burner down to maintain temp without pumping out so much heat and carbon monoxide. It's hard to tell from your pictures but you are working in a VERY well ventilated area. YES? Frosty The Lucky. Quote
jester Posted April 12, 2019 Author Posted April 12, 2019 Hi Frosty! Thank you for the reply. I love how helpful this community is. Ok. So, 70psi on the gas reg to get to temp.and then back it down when it is at temp. Cheers As far as ventilation goes, the shed I'm in is enclosed, somewhat, but has two large windows and a door which are always opened and a fan going to circulate the air. I've previously been told this is ample... *shrugs* Quote
Buzzkill Posted April 12, 2019 Posted April 12, 2019 70 psi on the regulator?!?!? That would certainly explain the excessive dragon's breath! Not all burners behave the same way, but most of the NA propane burners I've used or seen tend to operate between about 5 psi and 30 psi in the forge. Quote
Mikey98118 Posted April 13, 2019 Posted April 13, 2019 I have never run the gas above 20 PSI to do work; just to check burner performance. Quote
jester Posted April 13, 2019 Author Posted April 13, 2019 OK. Cool! I've gotten some bad advice along the way then... Oops... I'll back her back down A LOT then. LOL My arm hairs will eventually grow back... Quote
Frosty Posted April 13, 2019 Posted April 13, 2019 2 hours ago, jester said: My arm hairs will eventually grow back... Again and again and again. . . New guys! My regulator is probably 30 years old and only 0-20 psig. it runs four 3/4" burners without starving them though I've only run 4 at once a couple times. I usually run the old T burners about 7 - 12 psig. The ribbons between 3-5 psig. though if I'm going to be running them more than about 5 hours I turn them up to keep them cool, say 5-6 psig. Frosty The Lucky. Quote
AdamTheSaint Posted April 14, 2019 Posted April 14, 2019 70 is way, way, WAY high. Like, 10 times too high. Quote
