February 22, 20197 yr So I have a chance to go look at and hopefully purchase a sawyer anvil next week. I have read through the buying an anvil guides. As well as tpaaat and the like. I know to bring a ball pien hammer and if I can find one before then a ball bearing. Is there anything I should know or that I need to look for In a sawyer anvil that would be different from a traditional (read London pattern) anvil.
February 22, 20197 yr Good Morning, There are many different sizes and shapes. Smaller Anvils are rectangular shape with slightly tapered sides. Larger Anvils are square (ish). There is no Hardy Hole or Pritchel Hole. Sometimes there is a finger groove in 2 sides. It is not similar to a London Style Anvil. Neil
February 22, 20197 yr Depending on the manufacturer. sawyers's anvils were often made harder than smiths' anvils, because tuning a sawblade was a much gentler procedure than hot-forging a thicker workpiece. Not to say that you can't smith on one, but you do need to be aware of the greater risk of chipping an edge with a mis-hit.
February 22, 20197 yr Author Alright. Good to know. This one is large and trapezoidal in shape. Seller couldn't find any markers Mark's but it fits other examples I've seen online.
February 23, 20197 yr As JHCC mentioned, they were never intended for hot work. Only cold blades. May want to radius the edges some to help alleviate chipping.
February 23, 20197 yr Author None I can post as of yet. I have seen pictures from their listing. I do not have permission from the seller. However if someone beats me out on it I will ask if I can post some pics here. And if I get it you know I'll be posting like I just had another baby.
February 23, 20197 yr these anvils are harder than most anvils (because hard material is being hit upon them, to an extent work hardening them.) check for little surface cracks or little round chips on the face I have come acrosss theese a few times. I really like these anvils fto forge on.
