Peter Wright Anvil
Ok, if on a Peter Wright anvil the first number is in hundredweight and the second being 28 can you tell me what 106 would be? I usume 134 as the weight am I correct?
Welcome to IFI! If you haven't yet, please READ THIS FIRST!!!
A hundredweight is 112 lbs, so 112+0+6=118 lbs.
English hundred weight is given as multiples of 1. Hundred weight (112lbs), 2. Quarter weight (28lbs), then 3. Pounds (1lb).
Easy to remember how hundred weights work,
first number is multiples of 112 pounds,
second number is 1/4s of 112 or 28 pounds per number, which can never be larger than 3,
third number is left overs which can never be larger than 27.
Just remember that a hundred weight is 8 stone and a quarter hundred weight is 2 stone.
(and note in 37 years of smithing I have see a couple of anvils that were mis-stamped and so broke the 0-3 and <28 rules
