ColinHeath Posted December 8, 2018 Share Posted December 8, 2018 Hello All, I have attached pictures of my setup to help with discussion. I was running my forge today and being very cautious around the burner not getting too hot as I have rubber hose quite close. my questions are: 1) Will the burner always get hot right the way through when running for some time and if so, should I be concerned about the burner (I appreciate the rubber hose is an issue) 2) Should I install a long length of copper tube or black iron to keep valve and rubber hose cool and not worry about the burner tube itself? Any help would be much appreciated. thanks, Colin Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 8, 2018 Share Posted December 8, 2018 The burner overheating like that is a very serious safety concern. The last photo appears to show why the burner has a problem. You need to use a carbide encrusted hole saw to open up the partial blockage in the top brick, so that the flame is unimpaired. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 8, 2018 Share Posted December 8, 2018 Do you have any burning in the mixing tube going on? Note the reason I do not like top mount burners is that when you turn off the forge they act as chimneys for the heat in the forge. Also they tend to recycle exhaust gasses more and so increase CO production. Quote Link to comment Share on other sites More sharing options...
ColinHeath Posted December 8, 2018 Author Share Posted December 8, 2018 Thanks Mikey, the bire through brick is same bore as outside of flame tube it’s just the picture makes it look off (the black bits is bottom of forge). Thanks Thomas, i don’t think any burning in the tube as it stays cool for a while before heating up although I had turned down gas pressure so maybe it was burning back into tube? what sort of burner do you use? maybe go for side mount like in a foundry? I am planning to make another forge so no problem to change Quote Link to comment Share on other sites More sharing options...
VainEnd84 Posted December 8, 2018 Share Posted December 8, 2018 Several questions, did you follow the T-burner build instructions exactly? And is the mixing tube galvanized? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 8, 2018 Share Posted December 8, 2018 I use a blown burner and 2 differing types of NA burners---depending on the forge. I will be building a couple of Frosty T burners when I do a total rebuild of my main forge coming up soon---it's about 20 years old now and needs more than the odd relining...The shell is O2 welding tank so it's in grand shape. The burners are a bit battered as it travels a lot. I think I'm on my 3rd set of regulators with it do to "trauma". Quote Link to comment Share on other sites More sharing options...
ColinHeath Posted December 8, 2018 Author Share Posted December 8, 2018 1 hour ago, VainEnd84 said: Several questions, did you follow the T-burner build instructions exactly? And is the mixing tube galvanized? No, I made this following other plans before finding this place. The burner runs lovely and assuming heat going back up is due to it being top mounted. Yes it is galv but it doesn’t get hot enough for that to be a worry (I know risks as I weld and fabricate and have had galv flu before so take it serious) Thanks Thomas my next build is a 15kg propane tank and have Kaowool to insulate and will them rigidise and coat to prevent fibres getting out. im thinking maybe a side mount for burner but wondered if there is a valid reason for top mount as so many do it? Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 8, 2018 Share Posted December 8, 2018 5 hours ago, ColinHeath said: im thinking maybe a side mount for burner but wondered if there is a valid reason for top mount as so many do it? I think the reason is simply convenience; most people find that valid. I don't. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 9, 2018 Share Posted December 9, 2018 The Lemming effect coupled with folks who think flame impingement on the work piece must be better. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 9, 2018 Share Posted December 9, 2018 Good one, Thomas. And here I was, wondering well all the humor went lately Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 9, 2018 Share Posted December 9, 2018 I'm still rattling around here aren't I Mike? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 9, 2018 Share Posted December 9, 2018 Yes, you are, but I like to hear the humor going around the table. Sometime you guys get on a roll Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 9, 2018 Share Posted December 9, 2018 Me too, it's fun to associate with guys who like punnishment. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 10, 2018 Share Posted December 10, 2018 Guilty as charged Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 10, 2018 Share Posted December 10, 2018 He's charged---how ionic! Quote Link to comment Share on other sites More sharing options...
