December 6, 20187 yr Just built a new 20 ton benchtop press. It has a 7.5 hp electric motor / 22 gallon p/m pump and a 4 in bore 8 in stroke cylinder. It weights around 400+ pounds dry and has a 32w x 32L x 45 T footprint.
January 15, 20197 yr oooh, I like it . Do you have any video of it working and moving metal? Is it quite loud? 7 hp. 3phase or single? circuit requirement?
February 3, 20197 yr Do you see the rubber-housed tubing under the front opening of the press? What happens when a piece of yellow hot steel hits and sits on it?
February 12, 20197 yr On 2/2/2019 at 8:59 PM, eutrophicated1 said: Do you see the rubber-housed tubing under the front opening of the press? What happens when a piece of yellow hot steel hits and sits on it? Thin piece of sheet metal to cover the hose, problem fixed and it wasn't that difficult :-)
April 27, 20197 yr On 12/6/2018 at 3:03 PM, Jack S said: Just built a new 20 ton benchtop press. email link removed What does one of these cost? What is the power supply? And where are you located?
April 28, 20197 yr Welcome to IFI Roger. I always suggest reading this to get the best out of the forum. READ THIS FIRST - You might also want to check out about quoting with pictures. The Quote Feature
