DungeonX Posted July 21, 2018 Share Posted July 21, 2018 Hi All, I am new and from Ontario Canada. I just started gathering the pieces to construct my first burner for my 20lb propane tank forge. i got 14T mig tips but they seem like they will be too small for the 1/8" schedule 80 pipe and that's before threading. what should I do? I'm having trouble finding a 1.25" x 1.25" x .75" reducing tee. And I have red handle plumbing ball valves,can I use those or do I need to find gas ball valves .25". I will probably come up with more questions. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted July 21, 2018 Share Posted July 21, 2018 Why the humongous oversized exhaust opening? Quote Link to comment Share on other sites More sharing options...
DungeonX Posted July 22, 2018 Author Share Posted July 22, 2018 that's my front end opening. I will use 2 " of kaowool, refractory cement and castable ITC 100. Here also is what I have so far for burner peices. Quote Link to comment Share on other sites More sharing options...
DungeonX Posted July 22, 2018 Author Share Posted July 22, 2018 my front end opening is 10" wide by 8" high and back is 3x5 Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 23, 2018 Share Posted July 23, 2018 Who's burner plans are you following? Those don't look like they're good performers, especially using a bushing reducer to connect the T and the mixing tube. It's going to disrupt the smooth flow and inhibit induction. Were I you I'd look up better "Side arm" type burner plans. Try Wayne Coe's site, he also has proven plans for a 20 lb. propane tank forge. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
DungeonX Posted July 24, 2018 Author Share Posted July 24, 2018 Thank you for the help Frosty. I have gotten to a larger city and have been able to get 2 of the proper ward reducing tees, and I am ordering 2 SS Flares from Zoeller forge. My biggest problem now is that the 14t mig tips seem to be to small for the 1/8" black pipe. Any ideas for me? Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 25, 2018 Share Posted July 25, 2018 You're welcome, it's my pleasure. I'm afraid I'd have to lay my hands on the parts to be of much specific help. I live in a relatively small city, REALLY big for Alaska but small for most of the world and I have trouble finding fittings that match up like I expect. The brass fitting I use as an adapter to mount the mig contact tip in and connect to the copper tubing supply line is getting almost impossible to find in a useful form. Low bid suppliers so they aren't consistent anymore and the ID isn't important to the intended purpose of the fittings. I'm afraid this is where you need to put on your creative improvisor's cap. If you can keep them aligned well enough you can silver solder the mig tips in. Or maybe fill the end of the pipe nipple with silver solder then drill and tap. The second will be harder to keep straight though. You might try different suppliers check the thread size of the mig tips they carry. Yeah, they vary by brand and in some cases within a brand. Thinking about it I don't know what a 14t mig tip is, metric probably. Yes? Our good luck threading 1/8" pipe directly to fit mig tips are SAE threads 1/4" x 27tpi. It may not work for a metric pitch thread, I don't know. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
stevomiller Posted July 25, 2018 Share Posted July 25, 2018 Frosty and Dungeon, I looked up the 14T tip, it is a Tapered #14 Tweco. Factory manual states that it is a standard UNF 1/4-28 thread, so I’m not sure why a schedule 80 1/8” pipes ID is too large to tap. Is it possible you got 11 T tips accidentally?They are 6mm which IS smaller, or that your pipe is actually schedule 40? Best Steve Quote Link to comment Share on other sites More sharing options...
DungeonX Posted July 25, 2018 Author Share Posted July 25, 2018 I have 14T mig tips but they are not "tweco" they have an "ms" stamp on them. I asked at the pipe cutting shop for 1/8" schedule 80 and I believe that's what they gave me. I was thinking about getting and end cap and drilling and tapping it to screw the mig tip in to. Quote Link to comment Share on other sites More sharing options...
DungeonX Posted July 27, 2018 Author Share Posted July 27, 2018 So today I got my collars tapped and welded on to my tank and I have finished my two 1" layers of Kaowool. I also got my mig tips silver soldered in place Quote Link to comment Share on other sites More sharing options...
DungeonX Posted July 28, 2018 Author Share Posted July 28, 2018 And part of my refractory is on Quote Link to comment Share on other sites More sharing options...
