Nhvalentine Posted August 12, 2017 Share Posted August 12, 2017 So, I recently acquired my first anvil and post vise from the same antique store. I needed a way to mount my "new to me" tools and after a few days of deliberation, this is what I came up with... The base is made from 4"×6" treated posts that I sandwiched together with stainless steel all thread nuts and washers. I planed the top level and sanded it all smooth. I also recessed all the bolt holes with a large paddle bit so I didn't get anything snagged or cut on the ends. I'm still not sure how I'm gonna mount the anvil to it. I'm being weird about it / very particular. I think I might just forge my own brackets. Any suggestions and or constructive criticism would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted August 12, 2017 Share Posted August 12, 2017 Greetings NH, Anvil base could be used but the vice mounted on the same unit not so much. You will soon find out that you will need access to all sides of your new anvil.. I suggest that you do some research on anvil stands and post vice mounts on this sight . I myself have posted several.. You will do well. Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
CMS3900 Posted August 12, 2017 Share Posted August 12, 2017 I think you have a solid base, but you might find the vise in the way in the future. I would suggest separating the two. The easiest way to attach the anvil is forge brackets like you said and lag bolt it to the base, or use chain and lags. I dunno if you know about them already, but I would check out the Blacksmith Guild of Central Maryland in Westminster if you get a chance. Good local resource and great people. http://www.bgcmonline.org/ Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted August 12, 2017 Share Posted August 12, 2017 If not, I would suggest widening your stump so the anvil can be turned with the heal tord the vice and a goodly distance between. You will find that you switch sides or stand beside the horn. Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 12, 2017 Share Posted August 12, 2017 1 hour ago, Charles R. Stevens said: If not, I would suggest widening your stump so the anvil can be turned with the heal tord the vice and a goodly distance between. You will find that you switch sides or stand beside the horn. Another point to add to Charles suggestion would be to turn the vise and lower it so the jaws can hold stock on the anvil's face for you. With the jaws in line with the anvil it will allow you to work all the way around the jaw on the far side. Both tools really REALLY need clear access all the way around for maximum utility. There are vise anvil combo stands where the vise drops into a receiver on the anvil stand, hardy hole or clamp to the anvil. This keeps it out of your way for regular forging operations but quickly available when needed. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted August 12, 2017 Share Posted August 12, 2017 Greetings NH, The best way I have found to mount your anvil is to trace the base pattern than use a router to cut a 1/2 inch well to set it into. Than two simple brackets to hold it down.. Vice mounting is all about available space. Enclosed one of my portable set ups that is easily moved . Good luck Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
Nhvalentine Posted August 12, 2017 Author Share Posted August 12, 2017 The post vise is simply held in place by the square nail in the picture. I can just tap it with my hammer and the entire vise comes off in about 30 seconds. Same in reverse. The post that it mounts to will still be in the way a little bit but the top of the post is about 3 inches lower than the top of the anvil. Quote Link to comment Share on other sites More sharing options...
Lanfox Posted December 14, 2021 Share Posted December 14, 2021 Keeping portability in mind, I like the design. The whole set up can be quickly moved off with a dolly. Quote Link to comment Share on other sites More sharing options...
