JHCC Posted May 3, 2017 Share Posted May 3, 2017 So, a construction site on campus is letting me salvage some scrap structural steel, a lot of which is your basic rusty mild. There are also some big pieces that might be great for welding into the base of a treadle hammer or something, but they're galvanized. Question: would grinding the galvy an inch or so back from any edges to be welded (i.e., beyond the HAZ) significantly reduce the risk of zinc poisoning, and -- if it does -- is it worth the bother? Or should I just salvage it to haul to the scrap dealer? Link to comment Share on other sites More sharing options...
Frosty Posted May 3, 2017 Share Posted May 3, 2017 Yes. Grinding it back is plenty of precaution depending on how heavy the beads are. That is however my dented head memory of book learning for my pipe and structural certification some 40+ years ago. Best check with the experts the AWS. This link should cover it but the AWS site is searchable. https://app.aws.org/technical/d1/d1-1article201007.pdf Frosty The Lucky. Link to comment Share on other sites More sharing options...
Glenn Posted May 3, 2017 Share Posted May 3, 2017 If you grind away the galvanized (zinc) coating you will be putting zinc dust into the air. This can settle and cover everything in the area, waiting to become airborne again when disturbed. IF you choose to grind, use a BIG FAN outside and blow the air shoulder to shoulder. This puts the zinc into the neighbors yard. A dip into vinegar will remove the zinc without spreading it around. Link to comment Share on other sites More sharing options...
JHCC Posted May 3, 2017 Author Share Posted May 3, 2017 Thanks. I'll probably salvage it and then think more about it later. Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted May 3, 2017 Share Posted May 3, 2017 Or bolt it together. Link to comment Share on other sites More sharing options...
Please sign in to comment
