March 15, 20179 yr No direct experience with these, but heard they may have plastic gearing. If so, I would be leery
March 15, 20179 yr seen one that looks like that, lasted a few minutes and the metal grill was big enough to get a finger in and razor sharp
March 15, 20179 yr Was that the "Standard British Finger" we used to have to check electronics with? (No live connections could be touched through any opening using the SBF...)
April 8, 20179 yr Old-ish post, but in case it's still relevant, a buddy of mine bought one of these, and uses it only occasionally, couple times a week at the most. After 2 or three weeks, he said the fan is beginning to grind against the housing and it's becoming more difficult to crank. I recommend against it. Try to find an old champion blower, or make one yourself if possible. Mine is made from an old blower out of an oil furnace, a couple belts and pulleys to give me about a 10:1 crank ratio from hand to fan (one rotation at the hand is 10 at the fan) some 1/2" rod as axles, and a 1/2" rod bent into a handle. 2x4 frame. Its kind of backwoods engineering, but it gets me up to forge welding temp easily. Just my two cents.
