February 20, 20179 yr I started building this gas forge in December 2015 and it got mostly done with the exception of the mortar and paint. Now Feb 2017 it has got those two items completed and has been put to use. It even cooks lunch while cooling down. Started with corn finished with a few snags.
February 25, 20179 yr Nice workmanship on the forge, she's beautiful. Being as you're using a commercial burner my first thought that the burner tube is WAY too long doesn't count. The commercial burner intake and jets are much stronger inducers than our home builds. I do have one safety based suggestion though. Using pipe to attach the gas line rather than hose makes it vulnerable to someone tripping on the hose and breaking the pipe. Of course how you have it arranged in the shop can put the gas lines and tank out of anybody's path so the longish pipe nipple on the burner wouldn't be an issue at all. Nice work, well done. Frosty The Lucky.
February 26, 20179 yr Author Frosty the pipe coming off the elbow is only short as it has a shut off valve in it. I plan to put it on a stand with the gas bottle below and a reasonable gap between. does that alleviate your concern?
February 26, 20179 yr I'm always concerned folk know the hazards they're working with. Sounds like you're on top of things mate. Frosty The Lucky.
February 26, 20179 yr 8 hours ago, FlyingXS said: Happy to hear tips on how not to set my self on fire.
February 26, 20179 yr I would like to hear a lot more about using it as a barbecue. It seems likely that anytime guys have a chance to make he hobby a welcome surprise for the wife and neighbors, its time to stop and take close attention on the subject
February 27, 20179 yr I still have my MOB (Mid Ohio Blacksmiths) Shirt that says: MOB Rule #1 Do not set self on fire! With a stick figure with it's hair on fire...
