jcornell Posted December 23, 2016 Share Posted December 23, 2016 My smithy is outdoors, in my back yard, under a maple tree. I've noticed that when the wind is blowing in the right direction, it takes all the exhaust gas coming out of the mouth of the forge and blows it up into the air intake of my T-burner (Frosty burner) which makes it sputter and flame out. If the forge is up to temperature, you just turn off the gas and when you turn it back on again, you're back in business. That got to be a bit annoying, so I noodled on how I could shield the air intake on the Frosty burner, coming up with all sorts of very complicated solutions. Finally inspiration hit, and I took the metal lid from a popcorn can (they're popular at Christmastime in the USA), punched four holes with a nail, took some hanger wire and wired it up to the Frosty burner. Thus far, the wind isn't causing my burner to sputter out any more Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 24, 2016 Share Posted December 24, 2016 A couple thoughts: If your forge is positioned in line with the wind it'll blow heat OUT of your forge, I try to position mine at 90* to help mitigate wind. A Christmas season popcorn tin lid to shield a "Frosty burner and you couldn't find one with a picture of Frosty?!" Some people, SHEESH! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
jcornell Posted December 24, 2016 Author Share Posted December 24, 2016 For you, Frosty, I'll try to find another lid. I usually buy my popcorn tins by how large they are, not by the picture on the outside, although I'm a sucker for kettle corn - caramel corn coming a distant second. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 24, 2016 Share Posted December 24, 2016 J You're getting off easy. The air openings on his design leans into shielding as a solution. Also, you appear to live in an area where the when blows in a predictable direction. In Seattle it tends to keep shifting until your hair falls out. It was always that way in the Aleutians too (only much worse). Mikey just HATES wind. Quote Link to comment Share on other sites More sharing options...
ianinsa Posted December 24, 2016 Share Posted December 24, 2016 You know the wind regularly comes from a predictable direction if they look like the attached image However your forge would become more efficient if you put it in a 1/4 drum ie. 44gal halved anb then halved in the opposite direction Quote Link to comment Share on other sites More sharing options...
New axe maker Posted December 24, 2016 Share Posted December 24, 2016 I took some non galvanized steel dryer vent hose that fits around the intake of my t burners and sits on the ground so the wind has no effect. Quote Link to comment Share on other sites More sharing options...
bigb Posted December 25, 2016 Share Posted December 25, 2016 21 hours ago, Frosty said: A Christmas season popcorn tin lid to shield a "Frosty burner and you couldn't find one with a picture of Frosty?!" Some people, SHEESH! Frosty The Lucky. Here ya go Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 25, 2016 Share Posted December 25, 2016 23 minutes ago, bigb said: Here ya go And I still can't get my hands dry! Frosty The Puddle. 20 hours ago, jcornell said: For you, Frosty, I'll try to find another lid. I usually buy my popcorn tins by how large they are, not by the picture on the outside, although I'm a sucker for kettle corn - caramel corn coming a distant second. This time of year the popcorn tins have Christmassie pics on them: snowmen, Santas, reindeer, sleighs, snow covered . . . everythings, religious, etc. The creepiest was a tin that was just Frosty's head, it looked positively sinister. I've tried a bunch of different wind screens and the best one on the shop forge was an open topped tin box. the new ribbon burners seem less susceptible but I haven't run it a lot yet, it's just too cold to haul my curmudgeonly old butt out to the shop, especially on windy days. The Ts have always been susceptible to breezes, a down check for sure. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
