November 24, 20169 yr Hi there, I found a bunch of cool junk in the scrap bin today at work including a big chisel someone had made and some old metal buckets and a slew of some sort of scraper blades. My question pertains to whether anybody can id what these blades are used for and if you think they'd be worth my time as far as knife making! I will spark test them when I get home but that's a ways off so I figured to keep myself occupied I'd make a needy post. Thanks for your time Spencer Dirks
November 24, 20169 yr Das, I thought you would have added that, given the triangular shape and the hole positions, the blade would make a perfect head for a praying mantis sculpture. We scrapologists think like that.
November 24, 20169 yr Aus, He was asking about possibly using them for knife making. I actually have some kicking around for when the time is right. Honestly, food coma is kicked in and I'm pretty well stuffed and struggling to stay awake after this Thanksgiving day feast. They are a perfect shape for a mantis head.
November 24, 20169 yr Das, are those sickle teeth made of high carbon steel, or are they like M2 and such which are weird ?
November 24, 20169 yr Never researched them myself. I'm pretty sure they are high carbon steel. I have a box with some new ones in I might be able to try to research. but mine will most likely be used in scrap art.
November 25, 20169 yr Dragon;s Teeth? We have two in the shop mounted to form a V to cut twine, light rope, etc
November 25, 20169 yr I tried looking mine up last night and short of calling the company I can't find out what steel or alloy they are. I'm not planning on making blades out of mine so I'm not that concerned. Tho that pack of new blades I have does sell for about $70-80. U.S. Spencer, best bet would be to test one out. Spark test, harden one and file test it then snap test it. That's the short version I found in a blade forum while trying to find out what steel they might be.
November 27, 20169 yr Author Thanks for all the advice folks! Daswulf in particular for the immediate id and advice! I haven't had the chance yet to spark test or harden but I'll post the results when i do.
