JME Posted May 22, 2016 Share Posted May 22, 2016 Was just given 2 heavy jack stands. Looks like I have a new anvil. They are made from some kind of machine steal and truck axle sections. Just have to weld them together, mount it and clean it up. I also was given the hammer in the picture. It feels like christmas morning. Quote Link to comment Share on other sites More sharing options...
7A749 Posted May 22, 2016 Share Posted May 22, 2016 Indeed. Nice score for sure! The hammer is icing on the cake!! Quote Link to comment Share on other sites More sharing options...
MrDarkNebulah Posted May 22, 2016 Share Posted May 22, 2016 I believe that hammer is used for sheet metal, but I may be wrong. Still I use a very similar one and I like it for certain necessities. Quote Link to comment Share on other sites More sharing options...
JME Posted May 22, 2016 Author Share Posted May 22, 2016 It is a sheet metal hammer. But any hammer or tool is welcome my place. :-) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 23, 2016 Share Posted May 23, 2016 Auto body hammer but if you ever work with sheet metal in the forge it might be useful. Quote Link to comment Share on other sites More sharing options...
JME Posted March 19, 2017 Author Share Posted March 19, 2017 I made a new anvil today. Used the jack stands, some RR track and some scrap I had in the shop. Took it all to work so I could use the welder there and a few hours later came home with this. Should do for a poor man's anvil. Just about killed me getting it out of the truck at home. 256lb. What do you think? BTW - the chain across the top is for use as a hold down. JME Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted March 19, 2017 Share Posted March 19, 2017 best way to use rail is on end, the bottom flange is the weakest part Quote Link to comment Share on other sites More sharing options...
JME Posted March 19, 2017 Author Share Posted March 19, 2017 True, but this way there is a sweet spot in the middle about 2" wide running the whole length of the rail. It has good rebound. I had the rail on its end but I was wanting something bigger that was more stable. We will see how it works soon enough. Haven't had time to try it out yet. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted March 20, 2017 Share Posted March 20, 2017 ugliest homemade anvil i've ever seen. kinda half like it though. Quote Link to comment Share on other sites More sharing options...
JME Posted March 20, 2017 Author Share Posted March 20, 2017 1 hour ago, Tubalcain2 said: ugliest homemade anvil i've ever seen. kinda half like it though. Ugly like me Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted March 20, 2017 Share Posted March 20, 2017 Personally, I think you need more mass under the face. Tell us how it works, though, once you've used it a bit. I don't think Tubalcain has seen very many homemade anvils. Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted March 20, 2017 Share Posted March 20, 2017 the only near sweet spot will be a tiny area directly over the legs, you need depth and mass mainly. for most things the working part of an anvil is not much larger than the face of your hammer when I get home tonight I will post a pic of an anvil I have made many years ago that has had much use and works well Quote Link to comment Share on other sites More sharing options...
JME Posted March 20, 2017 Author Share Posted March 20, 2017 3 hours ago, the iron dwarf said: Wen I get home tonight I will post a pic of an anvil I have made many years ago that has had much use and works well Thank you. I would love to see what it looks like 7 hours ago, C-1ToolSteel said: Personally, I think you need more mass under the face. Tell us how it works, though, once you've used it a bit. I don't think Tubalcain has seen very many homemade anvils. I will let you know. The jack stands under the one end are solid and are about 110lb by them selves. I hope they have enough mass. Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted March 20, 2017 Share Posted March 20, 2017 about 170 pounds, the horn is welded through the full thickness and is very hard steel, people have tried to break it by hitting the tip of it with a sledge and just sent the anvil flying Quote Link to comment Share on other sites More sharing options...
JME Posted March 20, 2017 Author Share Posted March 20, 2017 That is fantastic. Good job. I think I will be collecting materials for one like this. Quote Link to comment Share on other sites More sharing options...
JME Posted March 24, 2017 Author Share Posted March 24, 2017 Just tried out my new diy anvil. I like it. Lots of rebound and nice big "table top". The sweet spot is in the middle about 2" wide and runs along the length of it. No wobbles and sits very steady. It is not perfect but it will do me for a while. Quote Link to comment Share on other sites More sharing options...
