Errorgance Posted December 20, 2015 Share Posted December 20, 2015 hello! I'm new to the forums and relatively new to blacksmithing. So far I've managed to avoid making a sword, and instead I've been pounding out lots of coat hooks, tools, more tools, tools needed to make the tools, and tools to make making the tools i want to make more quick and easy. I swear, beginners budget blacksmiting is just making tools! the picture below is of my latest set of hooks, (this would be the 4th set I've made) and I think it shows. I hope you like it. Quote Link to comment Share on other sites More sharing options...
matto Posted December 20, 2015 Share Posted December 20, 2015 Like them a lot nice organic flow. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted December 21, 2015 Share Posted December 21, 2015 Actually I like it a lot. I think it could only look better if you antiqued the wood. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 21, 2015 Share Posted December 21, 2015 Nice job. The leaves are consistent through the set, that's a little harder than getting the rest of the hooks consistent. I can't tell from the angle but you DID roll the ends of the hook finials over far enough a heavy coat isn't hanging on an edge. Yes? Oh yes, making tools is an ongoing feature of the craft. Nobody but NOBODY makes the right one for THAT darned job, gotta make it yourself! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Errorgance Posted December 21, 2015 Author Share Posted December 21, 2015 9 hours ago, Daswulf said: Actually I like it a lot. I think it could only look better if you antiqued the wood. Thanks, I left it up to its new owner to treat it however they wish, though I am beginning to suspect most won't do a thing. 5 hours ago, Frosty said: Nice job. The leaves are consistent through the set, that's a little harder than getting the rest of the hooks consistent. I can't tell from the angle but you DID roll the ends of the hook finials over far enough a heavy coat isn't hanging on an edge. Yes? Oh yes, making tools is an ongoing feature of the craft. Nobody but NOBODY makes the right one for THAT darned job, gotta make it yourself! Frosty The Lucky. Sorry, I don't have any pictures from another angle. I think I understand what you mean, that a hard edge that will wear through, rip or catch on a heavy coat? Well no worry not, for these hooks now resides in San Diego Ca. "Heavy coats? What's that?" That said, I never thought about a hard edge/curve ripping through, version 5 shall be perfect! Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 22, 2015 Share Posted December 22, 2015 It drops below 40f in San Diego so sure they have heavy coats. You just want the point that takes the most weight to be smooth and reasonably large so coats, etc. can't snag or wear through. # 5 Perfect?! Oh, I get it you got me good there! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
jeremy k Posted December 22, 2015 Share Posted December 22, 2015 Throw a loop just below the leaf, so it points down about a 30-45º angle so it doesn't look like a snake as I've had many ppl told me when I started with similar hooks. Also, yes a wider coat rest. Quote Link to comment Share on other sites More sharing options...
ausfire Posted December 22, 2015 Share Posted December 22, 2015 Well done! Your punchings look good - well centred. Good to see you used black screws. Seems to me the broad top on the lower leaves would avoid any damage to the coats. I like them. Quote Link to comment Share on other sites More sharing options...
Errorgance Posted December 22, 2015 Author Share Posted December 22, 2015 14 hours ago, jeremy k said: Throw a loop just below the leaf, so it points down about a 30-45º angle so it doesn't look like a snake as I've had many ppl told me when I started with similar hooks. Also, yes a wider coat rest. Thank you, I'll have to try that next time, I imagine that will help prevent the snake look that my second coat rack badly suffered from! Quote Link to comment Share on other sites More sharing options...
