dcr135 Posted November 18, 2015 Share Posted November 18, 2015 Reading this forum was very helpful in getting ideas for building my own press so I thought I'd show what I came up with. Since my space is limited I wanted something with a small footprint. I ended up with a benchtop forging press that suits my Damascus steel making needs perfectly. After lots of research I decided to focus on speed rather than tonnage. The result was a 19 ton press using a 4" cylinder with 2.25" ram. To keep noise to a minimum the motor & pump assembly are mounted independent of the press. I also mounted the pump on a shop built bracket made from 1" steel plate to reduce vibration. Power comes from a 7.5 hp electric motor driving a single speed 6 gpm vane pump. Ram speed is ~2" per second. I'm currently running the press at under 1500 psi and making ~12 tons which (to my surprise) has been plenty for my initial 6x2x3 billets. Here's a very brief action video. https://www.youtube.com/watch?v=RUUsILQZq4s The design is pretty self explanatory but any questions are welcome. Thanks for looking, D. Crawford Link to comment Share on other sites More sharing options...
Alan Evans Posted November 19, 2015 Share Posted November 19, 2015 The only comments that spring immediately to mind are:- ...That I would put the pump unit in a box to reduce the hum ...Most importantly I would swap the connections on the spool valve so that pulling the lever down moves the ram down, and lifting the lever up raises the ram...when you are concentrating on the workpiece, intuitive control directions are a great help. I have very similar arrangement on my log splitter, when I first set that up I had it working the opposite way like yours, not for long.... My vertical metalworking presses are operated by foot pedals...you push the pedal down for the ram to come down... Looks neat and tidy as far as I can see from the video, I am sure your work will be well repaid. Alan Link to comment Share on other sites More sharing options...
pike3e Posted November 20, 2015 Share Posted November 20, 2015 That looks great. Any videos of it in action forging? Link to comment Share on other sites More sharing options...
flemish Posted November 21, 2015 Share Posted November 21, 2015 I would like an idea of what the press weights. Can you pick it up and put it on the table with out to much trouble? Flemish Link to comment Share on other sites More sharing options...
Gehljoe Posted November 22, 2015 Share Posted November 22, 2015 That's nice . How much time and money do you have in it ? Link to comment Share on other sites More sharing options...
dcr135 Posted November 22, 2015 Author Share Posted November 22, 2015 Alan, yes I definitely need to reverse the hoses between the valve and cylinder. Thanks. Pike3e, thanks. Not yet but I'll post when I do. Flemish, the press weighs a bit over 200 pounds with the cylinder. Thanks Gehljoe. I took about 2 years to read up on hydraulics, draw lots of sketches, and collect the parts little by little. I rummaged for scrap steel & bargain shopped all the parts except for the hoses and fittings. I probably have $800 or so in it. The build itself wasn't too bad and could be done in two or three weekends. Link to comment Share on other sites More sharing options...
Gehljoe Posted November 22, 2015 Share Posted November 22, 2015 Cool, i have been looking into buying a press . Would love to make one just don't have the welding tools or skills to do it. Yours looks very nice from the video. Link to comment Share on other sites More sharing options...
Eddie Mullins Posted November 24, 2015 Share Posted November 24, 2015 I have been wanting to build a press also, that is an interesting design. I like the compact size and the top mounted cylinder. What made you decide not to go with a two stage pump? Link to comment Share on other sites More sharing options...
dcr135 Posted November 24, 2015 Author Share Posted November 24, 2015 Eddie, I picked a single stage vane pump for two reasons. 1) They are supposedly much quieter than a log splitter type gear pump. And 2) A 6 gpm pump gives me the same speed after contact w/ the work piece as a 28 gpm two stage pump. The 28 gpm gives a quick approach speed but slows down to 1/4 of that once your pump switches to the high pressure mode. My press only has a max of 8 inches of travel so a fast approach speed would be of little value. I wanted speed after contact with the dies was made. Link to comment Share on other sites More sharing options...
the iron dwarf Posted November 24, 2015 Share Posted November 24, 2015 the gear pump I use makes virtually no noise, maybe 50% of what the motor makes when it is not driving anything and at a guess from your video ( unless you mounted a mic directly on the motor / pump ) less than one tenth of the noise that yours does. will be making a vid later this week I hope Link to comment Share on other sites More sharing options...
dcr135 Posted December 18, 2015 Author Share Posted December 18, 2015 Iron dwarf, I was a bit disappointed with the noise level of the vane pump. What type of pump are you using. Have a pic? Here's mine Link to comment Share on other sites More sharing options...
the iron dwarf Posted December 18, 2015 Share Posted December 18, 2015 mine is a gear pump which is inside the tank on the power pack, would have to dismantle it to get a pic. if I remember I can get a pic of a similar one tomorrow Link to comment Share on other sites More sharing options...
Alan Evans Posted December 19, 2015 Share Posted December 19, 2015 The hum in the video is more likely exaggerated by the auto sound level on the camera. Still if there is anything to be done to quieten it would be good news. The less noise in the workshop the easier it is to hear what is happening to the workpiece and the tool. I had to take the heavy cast aluminium belt cover off my 100 ton Finlay press and replace it with a wire mesh cage. The solid cover was acting like the sound board of a guitar and amplifying the rattle of the cam operated plunger pumps. Alan Link to comment Share on other sites More sharing options...
ptree Posted December 22, 2015 Share Posted December 22, 2015 Wow that is a loud pump! sounds like it is cavitating. Are you sucking oil up from the tank? if so you may have a small air leak and that will make the noise and kill the pump. If the suction line is undersized that will also cavitate the pump. Link to comment Share on other sites More sharing options...
Please sign in to comment
