September 23, 201510 yr My machinest friend has eyed an anvil he may be able to buy or trade work for. He took some measurements but its dirty enough he couldn't read anything. No pictures at this time.Hardy = 1 1/4horn tip to tail = 36"height = 14"face width = 6"What say ye?Kind of like guessing how many dimes are in a gallon pickle jar!Scott
September 23, 201510 yr Totally depends on make and style. A 36" Trenton is going to be vastly different than a 36" Fisher.
September 23, 201510 yr I can't remember the height of my anvil off the top of my head but it's 36" long, 6" wide with a 1 1/4" hardy and its marked 4-0-0 (448 lbs) so you're probably in the same ballpark. whatever the scales say its a good sized shop anvil, providing you don't have to move it too often!
September 23, 201510 yr My 35" fisher weights 400lbs, Several 36" Hay buddens that I know of are marked 400lbs, My 300 lb Hay Budden is 33"This sort of gives you an idea of the range.
September 23, 201510 yr Is it gracile or robustus for those dimensions? Old english style with a fat waist or cast anvils with fat heels may weigh 100 pounds more than a slim attenuated late 19th century American styled anvil. But yes it's big with the 1.25" hardy hole---unless someone enlarged a smaller one...
October 4, 201510 yr Whether it is cast, solid wrought, and how thick the face plate is all affect the weight vs dimensions. You'll have to weight it if you want to know.
