First attempt at Tongs
Well, here it is, my first successful attempt at tongs. they arnt pretty but the should work. i forged these out of 3/4in rebar. the next set i make will probably have welded reins, drawing out that rebar took a little to long for my liking haha.
They look pretty good for your first tongs.  Keep up the good work.  (A lot better than my first set, I might say.)
Definitely something to be proud of. Personally I'd never tried movin that much steel without some help in the shop that day lol.
Wow! 3/4 rebar! You're keen. How are the blisters on your hammer hand?? Well done!
thanks guys! yeah the 3/4 rebar was a bit of a bear to draw out but not too bad as long as it was HOT(using technicusjoe's technique for drawing out his rr spike tongs helped a lot also). as for the blisters, i dont have any surprisingly enough, must be from swinging a framing hammer all summer
I like them - good job. 3/4" rebar - what a bear. Do you have a welder? stick/ mig? - if you do, you can weld some round stock to the tongs (really puddle it) then hammer out the bead. Ok it's not "traditional" but it's quick and it works just fine.
Andy
thanks! yes i have both actually, i think i'll have to try that on the next set, might save me a bit of time..and my arm lol
  • 3 weeks later...
nice you only get better from here. Then get some 1045 and make tongs out of that is what the tong companies use
  • 2 weeks later...
already bought some :D just waiting till i get my technique down a bit better first. started a pair of bolt tongs the other day but ran out of time to finish them before work
