Cary Brief Posted April 18, 2015 Share Posted April 18, 2015 It was suggested by someone I trust that my next furnace (to cast a minimum of 50#) a pour should be a tilting one - I agree - I have a 21" diameter compressor tank to make that and my muller - but looking for plans. Chastain has a book but cant find a copy - they want $700+ on Amazon for it. and as much as $2k! anyone have any designs they can share? Thanks. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 18, 2015 Share Posted April 18, 2015 Cary; if you live in the USA you might be able to ILL a copy from your local public library. In rural New Mexico USA I have been able to ILL a copy of a books not available at all on Amazon---9 year standing search request! Quote Link to comment Share on other sites More sharing options...
Cary Brief Posted April 18, 2015 Author Share Posted April 18, 2015 i will give it a try! thanks Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted April 18, 2015 Share Posted April 18, 2015 I'm no casting pro but every setup I have seen has a movable ladle or crucible that is heated to melting temps in a stationary furnace. Even the big carbon arc setups in steel mills use a monster ladle on a crane while the electrodes are lowered into the melt. For 50# pours, it might be easier to design a furnace on the ground then use a set of two man tongs to pick up the crucible. A tilting furnace gives me all kinds of chills - like how do you handle fuel fittings on a moving setup that is well above 2000 degrees F.If you are trying to do big pours with no help, I think you'll need both a motorized lift and pivot on the crucible or it could get away from you and dump when you least expect it. I've had trouble with 15 lb pours working by myself and would hate to see what 50 lbs of molten anything looks like when it splashes. Think safety at all times... Quote Link to comment Share on other sites More sharing options...
arftist Posted April 18, 2015 Share Posted April 18, 2015 Tilting furnace is the way to go. My big Tilt/Pour was stolen. It would pour about 500# of bronze or 175# of aluminum.It was an expensive machine. I may know where there is a smaller one available if you are in the north east. Not sure if it is still there. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted April 18, 2015 Share Posted April 18, 2015 Arftist - I assume that was a commercial unit? 500# of bronze is a big pour - I haven't checked lately but bronze was running $5 a lb so that's an expensive charge. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted April 18, 2015 Share Posted April 18, 2015 We had a tilting induction furnace at the dental foundry I worked at, and we were pouring 25kilos at a time, so about the same amount. Overall it was pretty simple design.. Quote Link to comment Share on other sites More sharing options...
JNewman Posted April 18, 2015 Share Posted April 18, 2015 There is a small aluminum foundry around the corner from me that is closing in a couple of weeks that has 2 tilt furnaces I think they are both still for sale. They run on Natural gas and I would guess one is 50-100lb the other is a couple hundred. They are older furnaces and Dave probably does not want that much for them. Quote Link to comment Share on other sites More sharing options...
arftist Posted April 19, 2015 Share Posted April 19, 2015 Arftist - I assume that was a commercial unit? 500# of bronze is a big pour - I haven't checked lately but bronze was running $5 a lb so that's an expensive charge.Yeah, I bought it from an extruding company. They had used it to remelt the bar ends. Quote Link to comment Share on other sites More sharing options...
