Elk/deer horn
I've bent antler with boiling water and a little vinegar. I don't know what or if the vinegar does if anything but it was what I was given as instructions.
Clamp the antler between plates, vise whatever to straighten. Have it hot,well soaked so the heat is all the way through and go SLOWLY. Keep a sharp eye out for beginning cracks and reheat if they start to appear.
If I'm not mistaken the vinegar eats the calcium out of the antler  same as sticking an egg in a glass of vinegar  and turning it rubbery
So, here's what happened: I epoxied the antler on the tang (hidden) in the wrong direction as it had a slight turn that did not fit one's hand (right) well. OK, a little scotch may have been involved. After boiling it in water, the epoxy (West Sys) was soft enough to pull apart. Kind of surprised me as I thought it was much tougher. It's something to consider for the future. Not the scotch, but the epoxy.
John
Most epoxies take over 350f or so to let go....I wouild worry about wot happened....
Was that a 10 year old mix?
  • 2 months later...
That's the cheap fire water. Must be from SA. Nothing under 12 here...as you know.
