February 11, 201412 yr Hi all. have just got a second hand gas forge and was wondering if the burner tips are made out of stainless steel? the old ones have burrned out. Have just bought a vermiculite board to replace the fire brick on the top of the inside of the forge as i couldn't sorce a brick to replace the broken one. Thanks, any help would be great.[attac hment=63560:054.JPG] oh also how much of the burner should be into the box, past the top board? Thanks again.
February 11, 201412 yr Have you attempted to contact the maufacuer? Liners are a consumable as are burner flares. Failing that try one of the blacksmith or farrier supplies, as often some one has bought the old company out and is still making parts. As to the tips, my proforge uses the liner as the flare, so the tips of the burners are recessed in to the liner. By 1/2-3/4"
February 11, 201412 yr Author Thanks Charles,and iron dwarf, Yes i did try the web site ( Blacksmith snc, Italy ) but the site is comming up as having a virus, so thats out. I'm still not sure if the burners are stainless? as the old ones are burned out. Again many thanks for the reply. Cheers.
February 12, 201412 yr It appears as if the top of the forge has eroded and exposed the tips. I think they were probably resessed.
February 12, 201412 yr Author Thanks Charles, yes the fire brick is broke in half and missing when i got it, so i bought a piece of vermiculite board to fit the whole inside, and will cut out for the burners.
February 15, 201412 yr Everything I've read about burners says that the tips are not supposed to extend into the chamber. The ones you have do appear to be stainless, but that could just be the picture. Overall, the forge looks like a hoss! Three burners, manual chokes and a hefty door... very nice. The only thing I would caution would be to come up with some way of blocking off most of the forge so you're only running one or two burners depending on the work you're doing. I have a three-burner and can't imagine how much gas it would burn if I used all three! Definitely paint the inside with an IR reflector like Metrikote or ITC100.
February 18, 201412 yr Author Thanks VaughnT, i live in Ireland so don't think i can get IRreflector but i'll try. Thanks again.
February 18, 201412 yr IR reflector before mixing with water is very light. You could probably get it shipped reasonably. Wayne Coe sells some (google Wayne Coe blacksmith), might ship internationally. Also, pottery and glasswork face similar issues. Look for Kiln supplies and glass work supplies, you might find something.
February 19, 201412 yr ITC is commonly used in gas forges in the UK. If you search for it on the British Blades forum, I think you'll probably find references to suppliers as I know it's come up on threads there often enough.
February 21, 201412 yr Author Thanks Eric, and Ratel10mm, will have a look, i also messaged them (Blacksmith snc) on facebook, so hope to here from them.
February 21, 201412 yr There are one or two different recipes for a poorman's version of ITC100 knocking around. Essentially they tend to be around 2 parts Zirconium Silicate to 1 part china clay powder, mixed to a paint-on consistency with either water or blanket rigidizer (Sodium Silicate) for more absorbent surfaces. I think many of the batt wash formulations may have a high enough Zirconium Silicate content to work well. You should be able to find the stuff at any decent pottery suppliers. RPM might be worth a try. Failing that, Ulster or Scarva in the North.
