My new hardie hot cut
I thought you guys might like to see this. I recently acquired a new anvil with an 1 1/4" hardie hole and didn't have any tools for it. I decided to make a hot cut from H13. The only thing I could find that was big enough was a piece of 2".  I decided to give it a try and see what happened I ended up with a nice functioning tool. It doesn't look that pretty and it got a little crooked on me but it works like a champ. The hammer is short handled 10lb sledge that I used to do most of the work. I hurt so bad the next day I didn't know if it was worth it or not then I used it to cut  some steel today and I forgot how much it hurt already!
post-45245-0-05728100-1388280855_thumb.j
post-45245-0-05776500-1388280864_thumb.j
post-45245-0-61130600-1388280871_thumb.j
post-45245-0-32357400-1388280880_thumb.j
Nice looking hardy Zachary. What do you mean it got crooked? All I see is a carefully calculated and crafted differentially curved edge so a smith can perform highly precise cuts in an efficient manner. All the high end hardies are made like that. <wink>
Not to be a semantic jerk but the tool IS the hardy and there are only two bottom tools properly called a hardy, "hot" and "cold" hardies. Everything else is a bottom tool though things like bending forks and bics may have a different name.
Well done.
I need to get somebody to teach me how to keep the blade square with the hardy shank. I saw it happening when I was about half done and tried to straighten it but no luck. Til I was done I hurt so bad I no longer cared as long as it worked!
  • 3 weeks later...
