Anyone have any idea what this is?
I picked this up in a junk store for the simple reason that I have never seen anything like it before.
It looks/feels solid steel to me, about 5 to 8 lbs... 4 inches tall, 5.5 inches wide at base and is perfectly round... I paid $7 for it.
Not sure what Ill use it for, maybe just a paperweight but it would be interesting to know what its actual purpose is.
post-47439-0-28467200-1382731905_thumb.j
Greetings Planta, Looks to me like a scrap from a large lathe cutting operation The end cutoff from larger work Forge on and make beautiful things Jim
It could be a jig for pressing things in a hydraulic shop press.
I can see how that could be the case. Makes sense.
It might be a practice piece worked at school by machinist student....Looks kinda useful or decorative......... B)
It looks pretty cool... you could always resell it as a 'decorative jewelers anvil' on ebay, I'm sure you could make money on it. :P
Looks like you could hammer out a ton of small-diameter rings on it, in just about any size that caught your fancy :)
Dave
Looks to me that if you had to make a lot of identical circles or even just bends on "J" hooks, you could use this to gauge accuracy. Or even use it as part of a home made bending jig. The longer you stare at it the more options will come to your mind.
Either way, you got a steel. Pun intended.
Nice find.
Mark
@ Marksnagel, "Either way, you got a steel. Pun intended." Now that made me laugh!
I doubt it's a press die, no relief. I'm betting it's a cut off from a turning.
It will make a handy thing for forming on, rings or curved flanges/lips.etc. Maybe shine it up and use it to keep drawings on the bench. I'd put it somewhere I could find it, something it's good for will occur, bet on it.
The bug's got you, you're already picking up likely looking steel.
It's a jeweler's ring sizer.  With one of those, a jeweler is able to make rings and arc segments of a very specific size for bracelets, earrings and necklaces.  The top would also double as a small anvil.
I have some similar tools for driving bearing shells and seals into place. Nowadays they are a one-use throw away item made from tin or plastic.
You have Nailed it ! it is a Jewelers Bench top anvil for repairs of different items such as rings, bracelet, and such my wife's aunt is a jeweler and has one for just that .
Sam
