Going to look at an anvil tomorrow; looking for some advice
So tomorrow I'm going to look at an 80# English anvil. The guy I talked to said it was in good condition and is asking for $150. Im planning on checking the rebound and ring of the anvil but I was wondering if I could get some tips on other things to check for; markings, things like that. The price of $150 sounds fair for an 80# anvil assuming its in good condition. Any thoughts or advice?
It's less than $2 per pound and that's a decent price.  Figure in the cost of travel and you're still getting a decent purchase if the anvil quality is there.
Take a straight edge to check the amount of swayback.  Look at the edges for chipping.  Pay attention to signs that the anvil has been welded on to make the face look better.  Does the horn come to a decent point or is it missing some?
Chipped edges are not a deal breaker unless the chipping is severe.  Even then, a bit of time with a belt sander to radius the edges can work to your benefit.  Most smiths will do this as the radii come in handy for bending stock.
A bit of sway in the face plate can come in handy, too.  You don't want a ton of it, but a modicum won't hurt a bit.
The overall condition of the face plate is important.  I once had an anvil that had a faceplate that was like a rolling ocean.  There wasn't a single flat spot to be found and working on it was a constant struggle.  I would steer clear of something like that unless the price was really good.
There are enough pictures on IFI to show you what a good anvil looks like.
As Vulcan anvils go, that one is in decent shape.  However, please realize that Vulcans are considered to be on the poor end of the cast type anvils.  It will do for a starter anvil.  Just take it easy hammering on it.   The top plate is thin.  Keep your eyes open for a better one in the future.
Not bad at all.  While Vulcan's often get a bad rap, I think you did well.  The face is flat and edges look almost new, so run with it.
At 60#, you've got a great great great general anvil that's easy to move and can do 99% of the blacksmithing that you might like.  Currently, I have a 66#, 120# and 300# anvil in the garage, and each one is great.  Light anvils are a blessing when you have to move it out of the way or want to travel to do a demonstration.
Even when you find that bigger anvil, you'll keep this one around.  Promise!
I've heard of people 'dressing' their anvils, is this something I should do to this anvil, an if so how should I go about it?
Since Vulcans are prone to chipping, especially at the edges, I would radius them for sure because hard sharp corners are prone to chipping. I would use a 4 1/2'' angle grinder w/a 120 grit flap wheel or soft disc. and keep the grinder MOVING parallel along the edge till you like what you see.  A radius about the size of a common pencil eraser or a tad less would do and don't ever hammer cold iron anywhere close to the edges on that one. A little cold flattening of stock near the center I think would be ok..... B)
