Leafing Hammer
Mark  Emig
Here is an Aspery style leafinghammer I made. Started as 1" square 4140-weighs about 1-1/2 pounds. I'll make the next a bit smaller. I used the "toaster oven heat treat" that I learned from him-quenched at non magnetic, baked in the toaster oven for an hour and a half. Kind of "down and dirty" heat treat method, but it works well. I'm putting a black walnut handle on it, and leaving the temper colors on the hammer.
post-1460-0-13741200-1372101659_thumb.jp
post-1460-0-60040400-1372101731_thumb.jp
It's square, not flat-has a slight dome on it. It's for light work over ball stakes and such. Did it right out of M. Aspery's  book.
Thanks for that, it looked flat in the pic, camera angle I guess, can understand that and its use now.
