June 6, 201313 yr Hi, I was wondering if anybody has used this blower and if it is any good http://www.grainger.com/Grainger/DAYTON-PSC-Blower-1TDR3?cm_sp=IO-_-IDP-_-RR_VTV70300505&cm_vc=IDPRRZ1 Thanks, Sam
June 6, 201313 yr Good for WHAT???? Changing the air in a lavatory?? Wherebe is that that you is?? Add your location to your name. Sam Newbie calls home, Ditch twelve :) :) Neil
June 6, 201313 yr If you are looking in grainger check out the shaded pole blower, it has a round outlet with a flange make suer it has the cfm's your looking for
June 7, 201313 yr Author Has anyone had any luck with this blower http://www.amazon.com/Dayton-463-cfm-Exhaust-cord/dp/B0002HTF52/ref=pd_sim_sbs_hi_4 its 400 cfm and I was thinking I could hook a dimmer switch up to it to adjust the power its for this forge here :'?do=embed' frameborder='0' data-embedContent>> Thanks, Sam
June 29, 201313 yr Sam, 400 cfm may be more than you want, with the dimmer switch make sure it can handle the amperage or the switch will burn up. Larry
June 29, 201313 yr Sam: Dimmer switches can be problematical, where a simple swing/knife valve over the intake will do the job without risking electrical components. Frosty The Lucky.
