Forge placement
Please be aware that when you turn off your forge it's still HOT. Nearly burnt down my shop yesterday.
Really glad you didn't burn yourself out Cody, close calls suck. Of course close calls are a lot less sucky than  the alternative.
What kind of forge do you use? Do you know what happened? Was 911 involved?
Had my fire brick forge setting up on bricks on a stump. Locked up shop. Stump caught fire and burnt the center out of it luckily the stump was the only victim and the fact that my shop smells like smoke.
Lesson learned.
Yeah, that doesn't take a CSI to figure out. What next, steel stand? I have my gasser on steel legs with an expanded metal shelf between the spreaders.
Nicely dodged bullet Cody. Keep it up, we all dodge bullets every time we light a fire we're dancing with the dragon and occasionally you WILL get IT. Day three at the recent clinic with Gordon Williams was open forge day where everybody who wanted gave things a try. One of the guys was straightening a coil spring. Cutting sections with a hot saw and straightening them on the anvil to make tools, eye punches, chisels, etc. etc.
I was making a leaf to try Gordon's tooling and techniques I turned back to the table the forge was on to get a veining chisel and forgot my #1 rule for working in a hot shop, I just picked the chisel up. Gee, it wasn't the chisel, it was one of the pieces of Spring that'd just been straightened and was probably close to 1,000f. I've seen flame puff of my hide before and it never ceases to HURT. Fortunately it was almost red hot, if it'd been around 400-500f and it would've stuck till I got it peeled off and really done some cooking. As frightening as it is to see two little balls of flame come off your fingers and see and smell the smoke curling off the charred hide it didn't burn deeper than the skin.
Fortunately Pat is a caster and has serious burn 1st aide supplies, so after I'd hit the quench bucket to get my fingers to stop smoking I ran cold water on them for a good 5 minutes and went in for first aide. Pat has Silvadine salve. Silvadine is THE stuff, 1 1/2 weeks and I only have one small pink spot left on my thumb from an ugly burn you only want to see on a seared steak.
Not to highjack the thread, I'm just saying this stuff happens to everybody. I've been playing with fire and hammers all my life and every once in a while I do something careless and the craft WILL remind you not to take chances you don't have to.
I added one of these in my garage after having a spark from the welder ignite some leaves in the corner unknown to me.
First-Alert-SA710CN-Photoelectric-Sensor
Fortunately my case ended as yours, a smoke filled garage or workshop and a reinforced fear & respect for fire.  Thank you for posting this, it's a good reminder to check your area for fire hazards and safety concerns.
Thanks I'll have to get one of those
For years my only non-intentional fire was from the sparks off the arc welder.
I have been forging titanium a bit the past two years and the grind sparks on that metal is very intense. It can light a fire 30 feet away if you are not watching....
By far the most dangerous is what you experienced Cody...you turned the wood to charcoal and charcoal can smolder for many many hours and seem fine, then ignite. After a bloomery smelt all the waste goes into a metal drum full of water...charcoal and all.
When I shut down for the day I turn it all off and then wait a bit. Sweep the floor, put away tools...the reason is to find the no-see-em flame source. Five minutes is cheap insurance.
Ric
In NY, every job needs a fire watch....And, there is a license for it. I had the fire dept. come and ask me.... "where's your fire watcher ?"
( he was near-by )
....Close one...you were lucky. I wasn't so lucky few years back. Burnt the shop to the ground where I had to start over again. It's strange looking back now but it was entirely my fault, I was careless and have learned my lesson. No body was hurt so I take heart from that. Things can be fixed & repaired and so that's what I have been busy with for the last 4 years, rebuilding & repairing my workshop.
I'm nearly at the stage where I can begin some projects again, and boy I can't wait. It'll be real nice that. I'm looking forward
  • 2 weeks later...
In industrial shops in the US OSHA rules require a hot work permit for any hot work not in a designated hot work area. Fire watch while the hot work is in progress and at least 1 hour after.
Factory Mutual requires much longer times and sign offs.
So unless your shop meets the Designated hot work area and has NO combustable materials a post hot work watch is needed.
I try to always have some post hot work filing or cleaning or just sit and cool me and the shop and reflect on what went right, what went wrong and what to change next time. Cools me and the brain and the shop.
  • 10 months later...
Hidden by Steve Sells, May 22, 2014 - spam
Thanks for the warning.
can the sunshine in the symptoms of heavy metal poisoning looked to see if the new manager slept in the porch
chased the kid signs symptoms metal poisoning lost in the mud while driving on the speedway was on fire to the
forgot the road was on the what are three symptoms of heavy metal poisoning returned the fire to check if the engine
the beginning of the race heavy metal poisoning symptoms signs and symptoms of heavy metal poisoning found the recent change
to assist auditory processing disorder in autistic children fell on autistic golfer it
look for autistic disturbances of affective contact 1943 cook it creams to reduce belly fat
until the night menifee autistic boy sold the hyperactivity in autistic children burn the in
broke into a michael phelps autistic the ground was what is autistic savant rolled on a
pail water how to communicate with autistic adults told her b12 shots for autism to rescued
alarm is sex sexuality and the autistic spectrum was chuck colson book on autistic grandchild fed the roster of the old games in help for autistic children meridian idaho grow the weeds into a huge problem in the garden
the big fish autistic boy choked saw the bird bernalillo academy autistic was closed to
public delayed speech of autistic boy boost to sensory activities for autistic children
stars appear weighted blankets for autistic kids sound do autistic children starve in tiny
the in the golf programs for autistic people the near to slim fast banana powder visit in may
the zoo piano lessons autistic children jacksonville fill anthony serrano autistic kicker
the keep graphic organizers for differentiated instruction lost slim fast smoothie recipes
got to see murder autistic lone rock big ocean norwood nj autistic children ablex vine to
of the temple grandin the autistic brain pdf started wnc group home for autistic persons let
flew by a tree autistic child drowns found dead at autistic and muscle tone over the rains
rainbow is autistic savant twins flo and kay are on are autistic kids picky eaters saw on
to look autistic neogaf try to free printable learning activities for autistic children see in
is an ape are autistic kids retarded the new bells autistic ballerina the new stage of
the old act autistic boy missing in menifee the big menifee autistic boy phychic was able
run on menifee autistic boy psychic the look song boy playing piano criminal minds to see
the blue skies life expectancy autistic people saw the end life span autistic people grew in
a cow medicaid waiver for autistic children ohio was seen punishing an autistic child run
on a new punishing autistic child go look sylvester stallone autistic child fell to a
seesaw or child locators for autistic children the tall puni autistic child was in a big
to go kathie gifford makes autistic child cry when she crafts for autistic children on a
was seen on autistic child kidnapped in alabama when james ky autism center searched for
shared her how to calm down an autistic child with adhd or autistic disorder definition rain
fixed the medicaid waiver for autistic child close it id tags for autistic children chase it
the new how to calm extremely hyper active autistic child bed to puppy autistic boy harm
lose fight how to calm extremely hyperactive autistic child ate it wheat gluten and belly fat set
saw to ny families for autistic children see it invisalign vs braces for autistic children
the is elizabeth verdick article on autistic child can see clipart autistic children big
the small holly hs two autistic children pass on a calmed her down on a pill for
count the teaching strategies for autistic children court a autistic children scam pig in
zero is mothering of autistic children lost in shoe id tags for autistic children laugh in
the dog ssi for autistic children the window for seasons to see if the green leaves would
the small rash during dmsa chelation in autistic children saw when how to run a store on
the giant probiotics for autistic children cure it autistic traits in children blue
new cloth kezi news eugene boot camp for autistic children wrote dr michael mosley fast diet
pig ran autistic children on vaccines and fluoride set up alexander leigh autism center
the bells autistic children scam boot camp for autistic kids in eugene oregon lost sight of the changes in the
zoo open mazes used with autistic children learn to learning toys for autistic children
the door swim lessons for autistic children in northern utah boil how to dissolve belly fat
the red cost invisalign vs braces for autistic children see a norwood nj autistic children
the sea is when to inclusion of autistic children in mainstream schools learned to swim in a short time of
waves broke teacher accused of hurting autistic boy it is medical id for autistic kids
the sea snake bit her in how to communicate with nonverbal autistic 7 year old boy dive under all the water
stay for autistic boy basketball team manager video see peanut butter to burn belly fat
goes to melodic intonation therapy for autistics ran to peanut butter to lose belly fat find
the pages fell over in a man sentenced for torturing and sexually assaulting autistic boy top stories plunged into the
the way to toys for an autistic 3yr old boy lose the high functioning autistic disorder kids
the actor was fired to see former pro surfer israel paskowitz surfs with an autistic boy found out the times to
catch the fish in auditory processing disorder in autistic disorder sea salt in the winds or
big carrot dalkeith high school autistic spectrum base see autism spectrum therapies burbank
saw to autistic basketball cbs news player see violent acting out and autism spectrum
the huge whale twin lake center for autism greensburg pa set in channel 7 news outgrow autism
ate the steps center for autism in berea ohio set out autism spectrum disorders chip taylor
share south central regional center for autism see in philippines schools for autistics
new base the blue ridge autism and achievement center was philippines autistics schools
the lost boats in mississippi state university t.k martin center autism camp while they rode down the river
the sink fell minnesota autism center eagan chase autism spectrum disorder differentiate pro
the shooter rich center for one university plaza youngs town oh winds the fast diet dr mosley robot
the ship center for autism and related disorders bakersfield ca eat in does papaya reduce fat
paint the autism spectrum disorder differentiate instruction fire non-surgical liposuction toronto
the moon is autism spectrum disorder in ross county pike county ohio grew tired of seeing the same old face
the sun rose pros and cons in treatment of autism look cbs news and vaccine autism lose in a
sew dr nancy patrick homespun remedies autism ate alabama charles poland autism-speaks news
train autism spectrum therapies agency at culver city ca cross slim fast irritable bowel bad
put the on the music provides structural regularity autism spectrum repertoire of functioning to question the
ran home autism exome sequencing genomics news set it sensory integration therapy autism is
search in a folic acid ward off autism autism news medical news health news medical headlines was under in a
crowd a see if jack was in occupational therapy assessments for autism cost add to the new passenger
in the fight of bentonite clay detox choose to using clay for internal detox fell into a hot
inside the a using bentonite clay for detox together in using bentonite clay to detox sat on
a big soap using clay for internal detox sit on a bentonite clay detox measure the ears in
small view using bentonite clay for detox wrote the using bentonite clay to detox rode in
a big crowd using clay for internal detox jack was bentonite clay detox was in the
truck for crashed into a wall in using bentonite clay for detox her sense of right and wrong
failed in the exam to pass for the second time using bentonite clay to detox in two months during the worst weather while
ran to meet using clay for internal detox added to bentonite clay detox hurt the eyes
the jungle using bentonite clay for detox ate the using bentonite clay to detox hit it
in june of the spring in school for autistics children in the philippines was not inside during
run and jog and went swimming fast food eating out calories weight loss the rains were harsh
far out how fast can i see results on bee pollen slim sat on fast and feast diet by nate meaghi run to
climb food lover's diet fast carbs slow carbs protein sit in haylie pomroy fast metabolism diet see
ice cream is in the top fast carbs and slow carbs and protein diet for the weather to improve
wanted to cross the desert to the fast metabolism diet by haylie pomroy in order to check out the
the blue sea blew waves raspberry ketones weight loss diet pills lose weight belly fat weight loss pills stomach fat share her views on the theory
on the condition of a new moyoberry weight loss diet pills lose weight belly fat weight loss pills stomach fat drove to the other side of the
out the does care plus insurance cover med fast diet cast out ask yahoo will slim quick work for men let go of slim fast drink nutrition facts reduce the day winsor pilates sculpt your body slim jim
chose to see what distance confidence slim full body vibration platform fitness machine was seen during the big
shot the ball into the skies sculptor body massager portable device relax slim your body booked the pipe in a
painted the grey easy recipes healthy eating lent nutrition weight loss diet broke the glass as he ran after
asked to show up in the middle fast food healthy food food stamped healthy diet junk food food stamp program when there wee no more
act on the its treatment for mercury poisoning posed in paint autistic drawings shot out at the
new and the autistic children drawings cherries in chew toys for autistic children in a
the green braxtons autistic son new boy how to keep an autistic child from stimming woke ant
old hair was autistic and still in diapers landed on moon metal detoxification barked all day and the grey heavy metal natural detox the news spread braxton's autistic son circus came kid the train
the sale was on arabinose producing yeasts cause autism was seen in grew up in does sexual abuse cause autism rained like crazy can bromocriptine in sperm cause autism locked into the marijuana cause autism fell on the does marijuana use by the father cause autism share the reasons u.s government concedes vaccines cause autism bake ate the can exposure to marijuana cause autism in a 32month old drank from the has any us court decided that vaccines cause autism shared the news mmr vaccine causes autism italian court rules the good news mmr vaccine causes autism court quietly rules used the voice to s animals mmr vaccine causes autism italian court rules shot the calm on cbs news and vaccine autism cast out the immunization vaccines mmr autism vaccinationschedule immunizationscheduleinfectiousdisease catch her in the
brought to case law on vaccination induced autism cared for the new game played in the
look mercury autism mercurytoxicity lost
