Grundsau Posted December 4, 2012 Share Posted December 4, 2012 I needed more of this wax and found that my local sources don't carry it any longer. After searching online I found it at this link: http://www.bwccompany.com/bowlingalley.html The can label looks different. Tried calling the company for info and always get their vx mail. So I left a message for them to call me. Anyone know if this is the original formula? Quote Link to comment Share on other sites More sharing options...
Farmall Posted December 4, 2012 Share Posted December 4, 2012 Butcher's is available through Amazon - here's the link Link Removed Quote Link to comment Share on other sites More sharing options...
doc Posted December 4, 2012 Share Posted December 4, 2012 Did you try contacting this phone # 1 508 481-5700 ? This the manufacturer in Marlboro MA. Quote Link to comment Share on other sites More sharing options...
Grundsau Posted December 4, 2012 Author Share Posted December 4, 2012 Thanks I had found it on amazon but didn't know if it was the same formula. The BWC company just called back and it's the same wax. They bought the rights to the formula from the Johnson Company but had to change the labeling. Quote Link to comment Share on other sites More sharing options...
Crunch Posted December 4, 2012 Share Posted December 4, 2012 Is it still carnauba? At one point my Dad was researching waxes for use in a factory's material handling equipment, and he said that carnauba was the hardest wax out there... Quote Link to comment Share on other sites More sharing options...
Grundsau Posted December 4, 2012 Author Share Posted December 4, 2012 The BWC folks told me carnauba is still in the formula. Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted December 5, 2012 Share Posted December 5, 2012 Is it for hot waxing iron? Quote Link to comment Share on other sites More sharing options...
eric sprado Posted December 5, 2012 Share Posted December 5, 2012 I've used both Johnsons Paste Was and Butcher's. About the same results. You can still get Johnson's in Safeway.. I switched to the homemade Linseed Oil,Turpentine,Bees Wax formula listed on here and like it a LOT. At lease I know what is in it...... Quote Link to comment Share on other sites More sharing options...
Grundsau Posted December 5, 2012 Author Share Posted December 5, 2012 Frank, yes it is. Eric, I've tried Johnson's and it doesn't look as nice as butcher's. Will have to try that recipe. Quote Link to comment Share on other sites More sharing options...
PeteH Posted December 5, 2012 Share Posted December 5, 2012 You also can get pure carnauba wax flakes from some Amazon vendors -- probably elsewhere too. Not cheap -- about $22 a pound. Quote Link to comment Share on other sites More sharing options...
eric sprado Posted December 7, 2012 Share Posted December 7, 2012 I wonder if Carnauba flakes could be used in place of the bees wax in the homemade wax formula....Something to try.. Quote Link to comment Share on other sites More sharing options...
PeteH Posted December 7, 2012 Share Posted December 7, 2012 Probably would work. Carnauba's got a pretty high melting point, compared with beeswax. And it's hard, so it's possible the coating may show whitish where things rub against it. BTW, my grandfather (B. 1884) used a homebrew that was sorta like that formula, for cleaning/refinishing wood. Mixture of turpentine, linseed oil, alcohol, and some beeswax. The stuff would separate on standing, so he'd shake it, and then rub it into the wood with fine steel wool. Let dry overnight, and buff with a cloth. Did a nice job. Warning: If you try this, be sure to wet down the used steel-wool and rags with water, and dispose of them safely; Spontaneous combustion is REAL. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 13, 2012 Share Posted December 13, 2012 Well, I was hunting around home Depot yesterday and ran across the paste wax section and the Johnson's had an Original Formula can so I read the ingredients which contained Canauba. I just finished searching Johnson's Original and it listed Carnauba as the first ingredient. Not saying Johnson's is any better than another brand, just glad to see carnauba's still an ingredient. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
jmlyness Posted May 19, 2014 Share Posted May 19, 2014 Hello, Not sure if you found Butcher's or any paste wax for that matter. Here is a link if you are still looking for an old fashioned carnauba based paste wax. Link removed Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 19, 2014 Share Posted May 19, 2014 Hello back and welcome aboard, glad to have you. If you'll put your general location in the header you'll be surprised how many of the IFI gang live within visiting distance. Thank you for the link, I've been hoarding my last can of Treewax for quite a while. Carnuba is IMO as good a finish for wrought work as I've ever used. The Permakote you're linked us to looks to be a very similar product and I'll be giving it a try or watching for someone else's report. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
windancer Posted May 20, 2014 Share Posted May 20, 2014 Dave Hammer told me about Butcher's Bowling alley wax and that is all I use now. Seems to give a harder and more even finish. Dave Quote Link to comment Share on other sites More sharing options...
