GustavDebels Posted July 7, 2012 Share Posted July 7, 2012 I've finally got the verbal "go ahead" from my parents to start planning the long needed remodel of my bathroom. To cut to the point, i was thinking about making most of the hardware myself (towel rack, toilet paper holder, shelf/rack, *MAYBE* light switch covers, ect.) So what i need to know.... 1. Does anybody have experience with this type of stuff? I know many out there do, but is there anything out of the ordinary i should know? 2. What can i seal the stuff with that will be safe for bath towels & such? Will beeswax rub off over time? The pictures were found via google, and are somewhat what i want to do. Quote Link to comment Share on other sites More sharing options...
Pat Roy Posted July 7, 2012 Share Posted July 7, 2012 For bathroom hardware, especially the towel rack, since there will be lots of moisture, I would use multiple coats of clear lacquer. Even then it may eventually wear, keep an eye on it. For some things I use a mixture of beeswax, boiled linseed oil and turpentine, this isn't one of them. Quote Link to comment Share on other sites More sharing options...
r smith Posted July 7, 2012 Share Posted July 7, 2012 make the towel rack out of stainless steel. Quote Link to comment Share on other sites More sharing options...
anvil Posted July 7, 2012 Share Posted July 7, 2012 All canbe done with linseedoil,turps,and beeswax applied hot,then cleaned with alcohol works fine. Just watch it over a year. Reapply vegetable oil cold if rust happens. Always clean with alcohol to prevent black getting ontowles. The finish will evolve nicely over time. Switchplate covers are cool. Make a cold chiseled to match the top/bottom curveof plugs. Roll outer edges to raise cover. They look great and fun to make. Quote Link to comment Share on other sites More sharing options...
John B Posted July 7, 2012 Share Posted July 7, 2012 Forge cold in aluminium and polish/buff to shine Twists look great and add strength/rigidity to them Quote Link to comment Share on other sites More sharing options...
eric sprado Posted July 7, 2012 Share Posted July 7, 2012 What's the mixture ratio of Beeswax/turpentine/linseed oil ?? Quote Link to comment Share on other sites More sharing options...
r smith Posted July 8, 2012 Share Posted July 8, 2012 What's the mixture ratio of Beeswax/turpentine/linseed oil ??1-1-1 Quote Link to comment Share on other sites More sharing options...
Naz Posted July 8, 2012 Share Posted July 8, 2012 I use 1/3 of each and make small batches at a time. I used to make large batches but found they dry up over time (probably the turpentine/mineral spirits) and don't go on as easily as when the batch was fresh. Let dry 10-20 minutes, then buff with a rag. Works great for me... Quote Link to comment Share on other sites More sharing options...
SoCal Dave Posted July 8, 2012 Share Posted July 8, 2012 I've painted some bathroom items and they have held up well. I have included some photos of TP holders that I've seen over the years. Quote Link to comment Share on other sites More sharing options...
anvil Posted July 8, 2012 Share Posted July 8, 2012 Some folks like linseed,turps, and beeswax as a paste.I like mine more liquid, so50/50 linseed and turps, and when using a quart of each, melt in a walnut/Golfball size beeswax. On hinges, after I put on this hot, I will rub the barrel with my lump of beeswax. This makes a great oiled barrel. Quote Link to comment Share on other sites More sharing options...
anvil Posted July 8, 2012 Share Posted July 8, 2012 I prepare this in an old gallon paint can with a lid. Put on the forge, and slowly heat til beeswax is melted. If it flashes, put the lid on. When done pour back into the original quart cans. They have a small spout, which when stored, will prevent evaporation, and should last a very long time. Also the small spout aids in applying with a rag. Quote Link to comment Share on other sites More sharing options...
