May 10, 201115 yr I found this on Ebay. He mentioned blacksmithing but I doubt it. I can't figure out what it is though. Anyone know what it is?http://cgi.ebay.com/Old-Tool-it-Blacksmith-Tool-/320697280567?pt=LH_DefaultDomain_0&hash=item4aab0c2837
May 10, 201115 yr Old school soldering iron. The large mass of metal helped hold heat while it was applied to the solder and the pieces being soldered. Regards, Tim
May 10, 201115 yr Some guys still like to solder with them... I much prefer a torch for big work and an electric iron for tiny stuff. The tip is usually copper... hold lots of heat and silvers well. You can usually get them cheaper at flea markets and antique stores than on Ebay.
May 10, 201115 yr I've seen a lot of them forged into wizard heads by blacksmiths; but most blacksmiths don't use them. Tin knockers do and some roofers. I have a friend who does copper roofs that still uses that type of iron for soldering.
May 10, 201115 yr These old soldering irons are also useful for flintknappers as they can be converted into spalling boppers.
May 10, 201115 yr It is copper stock to make a wizzard head from Actually have seen them made into all kinds of heads Of course the bigger ones made better stock
May 10, 201115 yr These old soldering irons are also useful for flintknappers as they can be converted into spalling boppers. Is that anywhere near the dohicky and thingamabob?:)
