September 15, 201015 yr I found this flypress at a local used machinery place. It's a Brown & Boggs. The sales guy says this thing weighs 2000-2500 lbs. Personally, just looking at the picture, I don't think it could possibly weigh that much. They're asking $950, which is apparently negotiable. Anyone familiar with this press? If it's as big as they say it is, it's way to big for my shop.
September 15, 201015 yr Can't always believe everything a sales guy says. I would go see for myself. Definitely worth the ride. By the way, if I could find a flypress too big for my shop (which would be great) I would put it outside.
September 15, 201015 yr What he said! Went to a lot of auctions that said "Large anvil" only to find out it was under 100#...
September 15, 201015 yr Judged on the one I have I would say more like 6 to 700 lb. with the stand. also look at the screw the thread is a fairly slow pitch. That does not mean it is not a useful item. only that it will not have the quick impact and rebound as a faster thread pitch. If it is not damaged or worn out the price is good.
September 16, 201015 yr Author You nailed it peacock! I was noticing the thread too. They also have this other press. It looked to be in rougher shape, same price. The thread looks different on this one. What do you think?
September 16, 201015 yr Definitly faster screw. Probably the one I would go for...if given the chance. Take a piece of steel and try them both out and see which you prefer. And as always, offer LESS! ya never know til ya ask.
September 16, 201015 yr That 2nd one looks like it might be a 2k# machine, not knowing where you are and what the press supply there is like I'd offer them $300 and go to $600. Press #1 looks ok, but those angled weight mounts make me think "ball flinger". I know that's not where physics says the mass wants to go but that was my first reaction!
September 16, 201015 yr How "good" is that dealer. New paint on old machinery is always a warning sign to me. Could be nothing, could be a bondo'd crack hiding under it. If you got as good dealer you can take the chance knowing they will stand behind it. But I agree: I'd go with the second one and wrangle a price reduction since it hasn't been gussied up---don't mention that the faster screw is actually what you wanted in the first place...
September 16, 201015 yr Hi...I'm currently looking for a press, maybe you wouldn't mind forwarding the contact info? Thanks. Ron Kollman [email protected]
September 17, 201015 yr If these presses are in good shape and adjustment and well oiled the rams should be at the bottom if they are a true flypress. The slow pitch thread makes these what we call a die proofing press around here. When you turn loose of a flypress the ram will start turning for the bottom on it's own, (unless it has Grant's mod).
September 17, 201015 yr You're right Peacock. The second one has a little faster thread but not near fast enough. They are useful, but not nearly as much as the fast threaded ones.
September 17, 201015 yr Author You're right Peacock. The second one has a little faster thread but not near fast enough. They are useful, but not nearly as much as the fast threaded ones. Thanks everyone, I guess I have a lot to consider. These are the only presses I have found within a reasonable distance from where I live, and I may be able to get them for a descent price. My question is, knowing that the threads on these presses are not that "fast", will they still exert the force needed for some cold work on say 1/4" mild steel?
September 17, 201015 yr I have a low number of thread starts on my screw press and when properly lubed it will seek bottom on it's own too---I have some lengths of pipe insulation slipped onto the dependent handles to mitigate THWAPPAGE when I'm jockeying the die or piece around and not paying attention to the relentless creep downward and the slow circling of the handles. (It doesn't have balls but rather a 42" dia toroid).
September 17, 201015 yr Author Hi...I'm currently looking for a press, maybe you wouldn't mind forwarding the contact info? Thanks. Ron Kollman [email protected] Here's the link: (905) 771-8678 or e-mail us at [email protected]
September 17, 201015 yr Thanks everyone, I guess I have a lot to consider. These are the only presses I have found within a reasonable distance from where I live, and I may be able to get them for a descent price. My question is, knowing that the threads on these presses are not that "fast", will they still exert the force needed for some cold work on say 1/4" mild steel? Ain`t but one way to tell.Bring steel.
September 17, 201015 yr Author What kind of cold work? I'm thinking about rosettes, candle cups and the like. I'm beginning to think these presses may be too big for my little shop. I may look at a hydraulic press instead. Slower, I know, but will take up less space in the shop.
