Posted
I have recently purchased and refurbished a logan /monkey wards 10x24" lathe and am looking for a taper attachment to fit.
Logan Actuator Co. is awfully proud of their new ones and I dont have a milling machine yet to make one. Anyone out there seen or heard of one for sale or trade or gimme for shipping cost ??? B) Thank you,
Clifford
Posted
Clifford
Clifford, Look on flea bay and craigs look. Look for a local machine rebuilder. I used one in SC to locate parts for an old wilton variable speed drillpress. They could not find a manual for it but arranged for a photo copy.
Hope ya score one. Long shallow tapers need the proper tooling.
Ken.
Posted
Taper attachments are nice, but you can cut tapers other way in the mean time.
Short steep tapers are done by rotating the compound.
Long shallow tapers can be done by offsetting the tailstock with the piece between centers. This will also need a lathe dog driven by the chuck, or faceplate if you have one.
There are also a couple of machinists forums out there; practical machinist is one that I know of. They have for sale sections.
Posted
Thanks for the replies fellas I have been using the compound
for doing simple non critical tapers but 2+ inches of travel
and re-locating for longer tapers is a pain.
Craig"s list and flea bay (Ha-Ha) haven"t been productive so far.
Again thanks guys Clifford B)
Posted
Clifford
When I got my first metal cutting lathe back in 1976, I was in the process of building a large woodturning lathe for columns and needed to cut some internal Morse tapers in the spindle and tailstock. I couldn’t find a taper attachment for the lathe I had so I built one. It was simple to make and worked so well that I put a set of plans together and sold them along with the blank stock as kits. I sold quite a few mostly to prison inmates, surprisingly.
I attached a pic of the ad that appeared in the April, 1977, edition of Popular Mechanics just for fun. I also attached part of the plans with the exploded diagram so if you want to make one, you could see just how simple it is. Sizing it for your lathe is a matter of calculation once you understand how it functions.
Posted
Ciladog; Thank you very much for the plans it will save engineering time on making one. I got spoiled having one on the lathes at former shops of employment,for ship drive shaft couplers, drive shafts, and taper fits on sawmill headrig bandwheel drive shafts pump shafts ect.I like the simple design that is most always the best.I have a retired engineer friend that always said use the k.i.s.s principle when designing something (ie) keep it simple stupid, that pearl of wisdom will stay with me always thanks again Clifford B)
Posted
you got me thinking...and Googling
http://www.strippingknives.com/tools/taper.htm
http://www.kinzers.com/don/MachineTools/lathe_projects/
http://www.gadgetbuilder.com/Taper.html
Phil
Posted
Phil
Thank you Phil; more info to digest (love it !!) there are lots of interesting points brought to light for consideration,in your sugested sites, also a pearl of wisdom I found while checking them out.
(ie) You have only to state a problem acurately, and you have in general stated the solution.
A quote from Thomas Edison..... That is so right on so many levels Thanks and happy hammerin B)
  • 3 months later...
Posted
Am I missing something? Is there supposed to be something attached here?
Posted
No Grant, you are not missing something. The post is. Got deleted in the fray so i'll repost here.
post-3873-0-03051600-1290340474_thumb.jp
post-3873-0-73529100-1290340485_thumb.jp
Posted
Thanks, ciladog, that looks like a simpler construct than the one by Burton, in the popular mechanics article. Does it clamp right to the back bed ways? The other design has one clamp on the bed, and the other end clamps to the carriage, with the upper sliding clamp on the disconnected cross feed.
Does seem that the use of a drill rod might be smoother in motion.
My compound only travels 4", it's an oldie, dosnt have a degree scale, seems like a taper attachment would be easier to set up accurately.
I need to cut some .098 per inch tapers, with a 1/2-13 end to fit the versamil attachment I want to use for milling on the lathe.
Posted
Yes, it clamps to the back of the lathe bed.
Any arrangement you come up with to fix the guide bar to the lathe at the proper height will work. The one in the post adjusted to the thickness of the bed ways. If you have a V bed, then you need to make clamps that will clamp to it.
The guide that clamps to the carriage doubles as a threading stop. That is why there is an adjustment screw on the right.
The plans are more to show how simple a taper attachment is to make then to have you make that exact design.
