welding a fire pot
6013 has it's place in my shop just because of its lack of penetration. I have an old axe head that was split right through the eye. Old friend who taught me welding tricks 40 years ago sewed it up with 6013 and you can't see where!!!! It,of course,is NOT to be used where penetration is required. Just a different rod for a different use.
  • Replies 63
Junk rod? Seems like a pretty strong choice of words. It has it's place in fabrication, does what it was designed to do; nothing more, nothing less. How does that make it junk? Is a 16 ounce hammer "junk" because it can't draw out 4" stock like a little giant power hammer? 1 lb hammers have their place in the shop too.
When I weld something I want it to stay welded therefore I chose an electrode that will perform in such a manner. If you do the weld test as described with the different electrodes you will most likely feel the same
I wasn't trying to be hurtful with my comments, just pointing out that 6013 has it's place and that it's not junk.
The things that 6013 rod were designed to weld will stay welded just fine when done properly.
I have used 7018 and mig on my fire pots with no problems the first one is made is now 10 years old.
Lets look an welding rods and what the lettering stands for.
E stands for electrode
the first 2 numbers 60 or 70 is the psi tensile strength the weld can withstand that is 60,000 or 70,000 most metal is rated at 50,000 to 60,000 psi so your weld is stronger than the metal
the third number indicates welding position
1all positions flat, horizontal,vertical, and overhead
2. horizontial, and flat
3. old term flat only
4. flat, horizontial,overhead and vertical down
and the fourth number is the current used
exxxo-Dcrp only
exxx1 ac and dcrp
exxx2 ac and dcsp
exxx3 ac and dc
exxx4 ac and dc
exxx5 dcrp only
exxx6 ac and dcrp
exxx 8 ac and dcrp
(dcrp) Direct Current reverce polarity
(dcsp) direct current stright polarity
So I hope this hepls and the type of welder you have will determine the rod you use
Nope, 7018 is stronger, and easier to get an X-ray quality weld with. It is used at higher amps, and is a 'slow freeze' rod. It just **will not** bridge a gap, and can't be used for open root or poor fit-up full penetration welds. For that, you need 6010 or equivalent 'fast freeze' rod.
6010 followed by 7018 has been a tried and true pressure vessel and pipe industry standard for decades.
O.K., so now a firepot is a pressure vessel?
If you have a HAZ and think using 6010 instead of grinding off the heat affected zone is O.K., it calls everything else you say into question.
We are not talking about code issues here, we are taking about welding a fire pot.
Can't anybody admit that this advice is B.S., 6010, 6011, 7014, 7018, 7024, and a host of other rods would be more than adequate, even if poorly applied, wet, welded uner water, with the wrong polarity.
By the way, with a little more practice, you may find that you can weld poor fitup with 7018, if you are good enough.
ya it all bs I have welded with mig wire and stick they both hold up this is not structial or critical its just a fire pot whats the worst thing that can the whole thing melts and ends up as a blob of xxxx at your feet. And if you are wareing the proper protive clothing you will walk away just fine rember that Blacksmithing is a dangerious indever. If you can not weld good than you should just bolt on some pipe and pour a hearth. What ever works for you. this should stir the pot LOL
Nothin` but net on that shot Francis!
As the famous shoe folks say"Just do it".No welder,then bolt it.No tools or bolts then borrow the neighbor`s shovel and dig a hole in the ground.
If it fails then let us know and we will avoid goin` down that road too.If it works then post it(with pics) and we can all add it to the "College of Smithing Knowledge" that holds class right here. :D
Top drawer advise right there.Thanks for being the voice of reason.
  • 3 weeks later...
I have made several firepots using 1/2" A-36 mild steel. I used 7018 rods to weld them up. I've never had a problem with my pot and the folks that got the other one's love them. I used 7018 because they are much smoother and can get x-ray quality welds.
So now we need X-ray quality smooth welds inna fire pot? I sure am going to hate tell one oldtimer his 20 yr old pot with the outside corners that could be used as files(blobs/holes)Said he used AC and got his rods from a scrap yard. Seen a lot of pretty welds fail and a lot of goober welds still holding strong.
Ken
You know what hasn't been mentioned yet?
Drill the edges and bolt them together, possibly using angle iron or bent flat straps to take up the edges. Avoid the whole welding argument entirely.
Phil
Just buy a cast iron firepot from Centaur and get forging.
  • 2 months later...
its a fire pot? go down to supercheap and get the cheapest mild rods sized to suit the house power/welder, (i use 2.4, 2.6) v the joins with a grinder and give to it. root pass and grind out any stuff ups, and 3 runs + till its full....and a bit.
i use 6mm, 10mm and 1/2", along with anything else i find scrap, never had one come back.
works for me.
Phil
Phil, Have ya ever noticed bolts subjected to heat tend to be impossible to remove or they snap. Welds don't have to be pretty in a fire pot (mine do)Best thing is a drop in pot with welded corners No fuss to repair.
Ken.
  • 3 years later...
Posted · Hidden by Steve Sells, January 7, 2014 - SPAM
A straight is when the participant achieves a 5 card succession such as two, three, 4, five and 6. The playing cards do not need to have to be of the identical match to qualify as a straight. When two gamers have straights, the participant with the best straight wins. For illustration, a straight of two, a few, four, five and 6 would be overwhelmed by a straight of seven, eight, nine, 10 and jack. A straight automatically beats a few of a form and decrease arms.
Find out which sites offer you differing ranges of enjoy based on experience. Some present event engage in or engage in among set teams of persons. If you are genuinely really serious, opt for areas that give you the likelihood to enter qualifiers for the Planet Collection of Poker or the Planet Championship of online poker. There are tons of massive cash, higher profile tournaments that you could finish up in, but you have to be ready to enjoy and learn with the big boys and enjoy on the web poker for authentic cash.
Apart from that, there are many slots tournaments which requite no entry charge. You can participate in people contests for cost-free. The cost-free slots games are readily available on sites completely focused to slots or on casinos' web-sites. Some of the on-line casinos offer totally free chips for participating in slots. Later your winnings will be deposited into your reward account.
It would look possible that provided these video games are software package centered the odds could quickly be manipulated. They most undoubtedly could be if the web-site selected to do so, even so this would not be a incredibly fantastic organization model for any online gaming concern. Really basically place, on-line gaming problems don't need to cheat. Gambling alone, is inherently lucrative to an casino equipment germany without having cheating the client.
When gamblers indulge into extreme gambling pursuits, they have a tendency to devote time and dollars at the price of their jobs and time with loved ones and pals. They are inclined to keep away from their in close proximity to ones, ensuing in distrust among them and their loved ones. Gambling at the price of a single's task final results in a decrease in the excellent of a single's skilled lifetime. Habit to gambling is certain to hamper one's profession.
Talk to a financial debt counselor about your gambling debts to reduce financial strain and come across out how to clear up economic problems triggered by your compulsive gambling issue. This is essential, mainly because the monetary tension that you have from gambling habit debts can actually generate you back again to gambling if not dealt with.
online gambling is not all poor. It's just undesirable for me. I lack anything that is extremely significant if you want to make any dollars actively playing poker on the net-discipline. I have no self-self-discipline. I have attempted every thing. I even acquired it in my head that I would be equipped to enjoy a couple hands a working day, get up about fifty bucks a working day, and then leave. That might not seem like substantially, but fifty bucks a working day would be in excess of a thousand pounds a month, and that's a good deal of dollars for me. And I even now couldn't do it.
There are numerous folks who are actually addicted to Zenda poker video games. The on-line adaptation of this sport is related to the original card version of the game. The total of poker chips you have considerably influences the standing of your match and the variety of gamers you enjoy with. If you have a shortage of chips, your upcoming selection is to acquire some from your Facebook account or earn the chips from other gamers. An additional way to get chips with your brief of them is to get absolutely free Zona poker chips. Most persons wouldn't look a reward horse in the mouth, so to converse, and would gladly take free of charge chips if they just knew how. Fortunately there are some approaches to achieve absolutely free Zona chips if you are patient plenty of to wait for you likelihood. In this article are a few attainable methods you can get totally free chips devoid of substantially headache.
http://www.forumvwbus.de/post.php?1
http://www.fxchatbook.com/newreply.php?do=newreply&p=280819&noquote=1
