March 21, 201214 yr Putting golf balls on the tangs I tend to hand my files in the slot between two boards
March 22, 201214 yr I don't know if it actually makes them sharper, but when I bought a bunch of files at a garage sale awhile back. It ran them over a stiff wire wheel with the wheel spinnign over the teeth. Made the bigger files feel sharper to me
June 27, 201214 yr I am interested with what you did with your dull band saw blades. I read somewhere that you stack the pieces together making it a nice "rasp". I wondered if you thought of considering that.
June 27, 201214 yr I stack dull bandsaw blades alternated with pallet strapping and make pattern welded steel billets from them. I have stacked sharp BSB pieces to make a tang saw for slotting materials for a tang, especially guards
June 27, 201214 yr I am interested with what you did with your dull band saw blades. I read somewhere that you stack the pieces together making it a nice "rasp". I wondered if you thought of considering that. There is a commercial product for woodworking that looks like this.https://www.leevalley.com/US/wood/page.aspx?p=65692&cat=1,42524 I have never tried this tool, but I have tried a couple fresh hacksaw blades stacked and clamped in a vise with mediocre, but promising, results. It did what I needed quickly at least. Phil
June 28, 201214 yr Another solution. I have I think 6 of these pouches and need to have another one or 2 made. Local carriage builders do upholstery work. They do very nice job on these pouches for me among other things. Gives me a place to stow several sets of sizes and varieties, some seldom used but indeed nice to have when you need them. Yes ALL of these files were in a box from a sale. Poor conditon. They now are sharp and ready to use (and have been used). I think I started with 45 or more.
July 3, 201214 yr Interesting. When using a file or rasp, a Burr grows on the tip. If you don't lift the rasp, this Burr points foreward,and interferes with the cut. So lift on the return stroke to prevent this. To do a quick and dirty sharpening, we must remove this Burr. This will extend the life of the file or rasp. Any acid will work. Some faster than others. We only want to remove this Burr on the tip. So first, clean the rasp of gradoo, including grease an d oils. Then make a baking powder slurry. Coat the rasp and let dry. Then lightly remove this from only the tip. Put in any acid From vinegar to whatever ya got. Soak til Burr is gone. The baking powder protects the rest of the cutting edges and removes the Burr. Voi la restored file/rasp. When done make sure to neutralize the tool in a baking powder slurry or other base to kill the acid, or it will continue to etch. Works for me. Stronger acids work faster,weaker slower. So watch and experiment. What ya got to lose? If dull, you can't use it. If you mess up a few, you still can't use it, so turn it into a snake, buy some more rasps/files and try again.
July 13, 201214 yr This thread is educational. I am learning a thing or two on what to do with dull band saw blades. Thank you all for sharing your expertise.
