urnesBeast Posted September 14, 2009 Share Posted September 14, 2009 BP1048 Side Draft Chimney | Blueprints 1000 I am planning on using the above side draft. Has anyone built one of these that went through a building inspector. If you have knowledge in this area, that would be great. I used this in my first smithy, and it was great. I considered it safe, but I want to know what code inspectors think. Doug Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted September 14, 2009 Share Posted September 14, 2009 I have, but building and fire codes, and their enforcement is local specific, so not a lot or room for on-line help. call your local office. Quote Link to comment Share on other sites More sharing options...
urnesBeast Posted September 14, 2009 Author Share Posted September 14, 2009 I am friendly with the firemen, I was going to stop by tonight. Even though things are local, what was your experience. Doug Quote Link to comment Share on other sites More sharing options...
Glenn Posted September 14, 2009 Share Posted September 14, 2009 urnesbeast, please go to the top of the forum page, user cp, and add your location. There may be someone in your area that can assist you. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 14, 2009 Share Posted September 14, 2009 Not an inspector, but there is code for fireplace chimneys through wall or ceiling. You can probably look that up for your area, or use national code if local code is lacking. You can also contact a chimney sweep and ask them about the codes, but they may want a consultation fee. Welcome to The Wood Heat Organization Inc. has some information, but I don't remember where on the site. Phil Quote Link to comment Share on other sites More sharing options...
Bad Creek Blacksmith Posted September 15, 2009 Share Posted September 15, 2009 My experience was that there wasn't any codes on forges. So I installed my chimney a little bit like a wood stove and used a 10" floor duct for the chimney. I have a side draft forge but the chimney goes through the ceiling and roof. The only requirerment was a letter from the Fire dept. for the insurance company. Check your building codes for your area. Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted September 15, 2009 Share Posted September 15, 2009 Only code here is that a blacksmith forge flue has to have no larger than 1/2 wire mesh spark arrestor on it.http://www.iforgeiron.com/forum/f7/brown-co-ks-blacksmith-shop-pix-9-19-08-a-7463/ Quote Link to comment Share on other sites More sharing options...
thecelticforge Posted September 15, 2009 Share Posted September 15, 2009 I had to pour a two foot thick reinforced concrete slab under my forge. The Chimney is only going to be 16 feet tall. It is a bit of an overkill, but it kept the code people happy. That was the only stipulation besides the chimney being 4 feet higher than the roof. Quote Link to comment Share on other sites More sharing options...
