Angus Posted May 6, 2009 Share Posted May 6, 2009 Well I need to dig out some info from you gentlman. A couple of days ago a fellow firefighters mother passed and it was brought to my attention that they would like me to forge up some sort of plac saying in memory of. You guys got any ideas I could sure use some. Thanks Angus........ Quote Link to comment Share on other sites More sharing options...
easilyconfused Posted May 6, 2009 Share Posted May 6, 2009 What are they hoping for? Size? Plate I take it? Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 6, 2009 Share Posted May 6, 2009 If you spell her name by removing the letters from the plaque, the negative space can stand as memorial to her passing on from this space to the next. Then say the rest in positive space to speak of the things remaining here. I know that isn't said terribly well, my BS must be low, I hope it gets the idea across well enough though. Frosty Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted May 6, 2009 Share Posted May 6, 2009 Shoot Frosty, I understood it so ANYBODY can. Sounds like a nice memorial. What were her hobbies, interests? Quote Link to comment Share on other sites More sharing options...
lanchie76 Posted May 6, 2009 Share Posted May 6, 2009 was she known by her loved ones by a pet name (nickname) ie rose, honey etc. something that can be made by you. Quote Link to comment Share on other sites More sharing options...
lanchie76 Posted May 6, 2009 Share Posted May 6, 2009 as for doing the plaque if you have a wielder you could wield the message to build it up then heat and hammer to smooth and give the hammered look. i know its cheating abit but thats how i'd do it Quote Link to comment Share on other sites More sharing options...
Angus Posted May 7, 2009 Author Share Posted May 7, 2009 The department want to buy a tree to plant some were on his property so they would like me to forge up a plak of some sorts to go in front of it Like( In memory of Name . And may i just say wow you guys have given me some good ideas. Lanchie76 i think i will try your idea see how that turns out, but keep the ideas coming guys I sure do appreciate it. I know nothing about her I didnt know his mom was still around John is in his 60's so that would have to make her 80 or more. Quote Link to comment Share on other sites More sharing options...
Jerry W. Posted May 7, 2009 Share Posted May 7, 2009 Angus, My aunt wanted a small memorial for a tree she planted in memory of my uncle. I acquired some metal letters from King Arch. Metals and gas welded them to the edge of some 1/8 X 1" stock and then added some posts. She had a flat rock that I was able to drill to match the posts. Took some scrap and built a stand for the rock to lean against. I decorated it with a couple of horseshoes. She was very pleased To a fellow firefighter, Good Luck, Jerry Quote Link to comment Share on other sites More sharing options...
ifitsmetal Posted May 7, 2009 Share Posted May 7, 2009 Starting to work on one as we speak. Here is the plan: 6" X 9" X .25 mild steel plate. Will tig weld .50 tall letter out lines onto the plate with ss wire. Frame above plate like a picture with hammered and textured 1" or 1.5" X .25" flat bar. 2 .50 square legs hammered and twisted with cross pc welded in between the two approx. 8" up from the bottom of the legs to help facilitate sticking it into the ground. Top of the legs to be bent at 45 degree angle where the above plate is attached for easier reading from a standing position. Customer wants it painted black. I will then take a small polishing pad and remove the black paint from the ss letters. We will see how it turns out. Did a similar lettering job all out of ss that is attached to a sunken memorial out in the Atlantic, it turned out quite nice. Good luck. Quote Link to comment Share on other sites More sharing options...
Angus Posted May 8, 2009 Author Share Posted May 8, 2009 Ifitsmetal.. sounds like a good project, one ? what is ss wire not being a mig welder i dont know that part of the welding terms im a stick welder. Hey and take some pictures I would love to see how it turns out. Angus Quote Link to comment Share on other sites More sharing options...
Charlotte Posted May 8, 2009 Share Posted May 8, 2009 ss= stainless steel. He is TIG welding using the stainless wire as filler metal. TIG is ideal for this because the gas shield lets you play with material a bit more. Quote Link to comment Share on other sites More sharing options...
SoCal Dave Posted May 8, 2009 Share Posted May 8, 2009 Maybe ss wire stands for stainless steel? Quote Link to comment Share on other sites More sharing options...
David E. Posted May 9, 2009 Share Posted May 9, 2009 Ifitsmetal.. sounds like a good project, one ? what is ss wire not being a mig welder i dont know that part of the welding terms im a stick welder. Hey and take some pictures I would love to see how it turns out. Angus ss is just short for stainless steel Angus. Quote Link to comment Share on other sites More sharing options...
David E. Posted May 9, 2009 Share Posted May 9, 2009 oops, didnt see the other posts. Quote Link to comment Share on other sites More sharing options...
Angus Posted May 10, 2009 Author Share Posted May 10, 2009 Duh, ok ss stainless steal. Quote Link to comment Share on other sites More sharing options...
