dablacksmith Posted April 1, 2009 Share Posted April 1, 2009 hi figured i would share some pictures of a group of dug spearpoints a friend of mine loaned me .. he said they were collected in san diego county ca. and are probably spanish colonial .. ive made a replica of one already Quote Link to comment Share on other sites More sharing options...
tech413 Posted April 1, 2009 Share Posted April 1, 2009 Thats cool, thanks for sharing. Where are the pictures of the replica?? Adam Quote Link to comment Share on other sites More sharing options...
Chad J Posted April 1, 2009 Share Posted April 1, 2009 that is pretty nice, even if they are loaners.:) Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted April 1, 2009 Author Share Posted April 1, 2009 ok here is the replica as forged .. i will finish it later and post picks as finished Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 1, 2009 Share Posted April 1, 2009 Thanks for the pics. The first thing that strikes me is how short and sharply tapered the tangs are on the two points at top. It makes me wonder how they were mounted to the shaft and how solid the connection was. Of course they could've just been socketed and expected to come out once stuck in something like a boar. That way the user could insert another point on the shaft and stick it or something else again. Any ideas? Frosty Quote Link to comment Share on other sites More sharing options...
Finnr Posted April 1, 2009 Share Posted April 1, 2009 Looks like a fun project. I have done both Norse welded socket spears and Anglo Saxon split sockets. It isn't the easiest job. Looks like you are getting excellent results. Finnr Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted April 1, 2009 Author Share Posted April 1, 2009 Thanks for the pics. The first thing that strikes me is how short and sharply tapered the tangs are on the two points at top. It makes me wonder how they were mounted to the shaft and how solid the connection was. Of course they could've just been socketed and expected to come out once stuck in something like a boar. That way the user could insert another point on the shaft and stick it or something else again. Any ideas? Frosty i figure they went into a socketed handle ... one was pinned in place (hole where pin went) and probably worked fine for mounted use (they are light enough to be more a lance head than boarspear)they might have had a little longer tangs also they are real rusted...no shaft to look at tho so no way to tell..I wonder why all of them have a ball section behind the blade but before the socket.it looks good maybee it helps the balance or has some significance. theyres my ideas... have fun Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 2, 2009 Share Posted April 2, 2009 Ball makes a good place to tie the streamers to. Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted April 3, 2009 Author Share Posted April 3, 2009 here is a couple of pictures of the point finished .. i didnt file it sharp but it would be useable as is .. it ended up a little heavyer than the original but not a bad representation.. will try again later.. Quote Link to comment Share on other sites More sharing options...
jimmy seale Posted April 4, 2009 Share Posted April 4, 2009 exellent work there, dab,what you use, mild?,keep it up, jimmy Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted April 4, 2009 Author Share Posted April 4, 2009 exellent work there, dab,what you use, mild?,keep it up, jimmy na used a old chizel (real rusty one) was about 7/8 octagon... forged it out but havnt tried to harden it fogure its is better off soft that way if it ever ends up stuck in a tree it will bend before it breaks...but cause its a high carbon it is a little tougher... Quote Link to comment Share on other sites More sharing options...
jake pogrebinsky Posted April 18, 2009 Share Posted April 18, 2009 Once again,dablacksmith,you've maintained an enviable(to me)degree of control on this.Right on.Here's an interesting batch of historic blades from a museum in Sweden:S Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted April 18, 2009 Author Share Posted April 18, 2009 that is a useable spear.The only thing i would change is the transision between blade and socket . I would forge that section on the blade edge sides by doing this it will upset the section there makeing it thicker in the other plane ..when it is close to square there then round it up by the normal method (octagon to round ) it will give you a little thicker stem for the spear ( probably not critical 1/4 thick spring steel is pretty tough).good luck! btw dont go after them bears with a spear.. ide hate ta find out ya got et.. Quote Link to comment Share on other sites More sharing options...
jake pogrebinsky Posted April 18, 2009 Share Posted April 18, 2009 Yep,i planned that transition poorly.The spring was 3" by 3/8" thick,and i was hoping that it would upset into more than it ended up doing.Welding the spring with all the Cr is not much fun,but next time will have to fold it and weld it up. So,you've isolated that part in the middle with a gillotine,good for you,worked well.Great when things work the way you mean for them to! And no,i don't go after the critters manually,some younger guys are into that.I do a bit of work locally,mostly in trade for the meat.Spear hunting is not done much here anymore,the gun is too efficient.I should have a photo of an old one,forged in Siberia,that was used around here.If i can find it...It's surprising how small it is,the blade not much over 6". Quote Link to comment Share on other sites More sharing options...
