2,136 -
Everything posted by Chris C
Thanks for the comments. I'm going to be applying Metrikote on top of the KOL, (an IR reflective material) so I don't think the KOL will absorb as much heat as it would without. I don't ever envision myself forging an axe head. But if I needed to do something that large, I could easily build a coal forge.
I've started laying out on paper the exact dimensions of my forge..........showing the inside measurement of the 12" pipe and the 2 1/2" thick K-26 soft brick all the way around. What I end up with is a forge cavity sized 6 1/4" x 6 1/4 x 17". Now I need to decide how thick to cast the KOL30. Originally my thought was to cast 1" thick all round. But that would only end up giving me a 4 1/4" square cavity. My primary purpose for building a forge is to make knives. I eventually would like to be able to forge weld (fake damascus) blades. So will a 4 1/4" square cavity be large enough to do that??? I'm thinking maybe not! So would 1/2" on the side-walls and ceiling of the forge and then 1" on the floor still give the brick plenty of protection?
steam locomotive grill. prok-master.
Chris C replied to prok-master's topic in Metal Sculpture & Carvings
Prok-master, your work is absolutely stunning. That's elevating "blacksmithing" to a true art form. Incredible work. Astounding. Not much else I can say except I like it. Прок-мастер, ваша работа абсолютно потрясающая. Это возводит «кузнечное дело» в настоящее искусство. Невероятная работа. Поразительно. Больше ничего не могу сказать, кроме того, что мне это нравится. -
The material I have has a polyethylene covering to protect it from scratches. I'll use angle iron in the inside corners and attach the plex to the corners with adhesive backed tape. When the KOL sets up, I'll just pull the angle iron away and the sides will be free to be pulled away. I'm going to wrap the form with parchment paper and heavily coat it with Crisco, so I shouldn't have any problems. (knock on wood)
571 pound new to me anvil
Chris C replied to SilentForge's topic in Anvils, Swage Blocks, and Mandrels
Damian, The best bet is to use Anchor Seal. You probably can't get it where you live. Check with people in your area who do wood turning. They often have to seal the ends of logs so they can dry without cracking. Probably the next best thing to use would be latex paint. -
I'm planning on making a plexiglass walled box for the forum, so it will not be absorbing any of the moisture from the KOL. (I actually thought ahead for once!)
Hmmmmmm............"butter" the bricks. I guess I could get them wet just before I place the square, collapsible form inside. Will they stay wet long enough to force the KOL into the gap between brick and form? This square tube is heavy. (too heavy, darnit) I'm not sure I can vibrate it adequately.
He-he, Frosty, why does it pain you? Is there something bad about refractory cement? I'd only need to use it on the bricks closest to the ends. I may not even need it if I cut my bricks so there's a slight tightness to the fit. I just didn't want to go to lay this thing down and have some loose brick go sliding out. Wait...........something just hit me.................I'll be covering the brick with KOL. Does that really stick to the brick? If so, the KOL liner ought to keep the brick from sliding. Yes?
I'm planning on diagonally bracing the cart............just didn't have any strapping. The stand on which the forge is sitting was built with pirated pieces from the packing crate from when I bought my zero radius turning mower. It was all bolted up on this contraption. Against my wife's wishes I kept the pieces. She claims I'm a hoarder............I say I'm a collector of things I will use some day. And I do use those things when the time comes. Just don't always know when I'll be able to use them. In this case, I think they worked rather nicely. I just need some more strapping. As far as weight on the cart lower down, I have room and plan on putting the propane tank on the lower shelf.
The extensions are 8"..........and as you can see, very well marked. I'm the only one who will be using my forge, so I'd think I could stay away from them.
Things are always distorted with a wide-angle lens. The center of the forge opening is 53". The wheels are 30" apart. This is no taller than the forges at our Thursday night group, and they are mounted on the same cart as I have..............except they just have the standard 11 1/2" wheel spread.
Fair enough, Frosty.
Next step in this forge building process is installing the soft brick. I've decided to stand my forge body on end and simply stack the bricks cut to size on all the side walls. I then plan to build a collapsible "box" form to set in the center so I can pour the Kast-O-Lite in-between the box form and the soft brick. After I'm finished with that and the application of the IR reflective coating, I'll lay the forge down on it's bottom. I'm concerned the bricks might not stay in place when I do that. Is there any reason I shouldn't use contact adhesive to apply the soft bricks to the wall of the forge to make certain they stay there throughout the fabrication process?
Egg-zactly! Can't wait to get my forge up and runnin' so's I can dabble is similar activity, JHCC.
No doubt! I'm making a Hardy cutting chisel for my little Vulcan out of the first one I was given several weeks ago. The 5/8" shaft to fit the tiny Hardy hole conjured it's share of laughter last week at the open forge. Oh well, gotta start somewhere.
I was a professional furniture builder for 17 years, so I've a well appointed shop. www.chrischristenberry.com Take a look at some of the stuff I used to make. Now I'm makin' wood carving knives......and gettin' into blacksmithing.........who knew?????
I'm blessed with a wonderful shop, Goat Lady. 30x40, air conditioning and wood heat. furniture building section, wood carving section, reloading section, bullet casting area............and a 4x8 workbench I seldom see. There's a 1 1/2 car wide, 2 car long room attached where I will set up the blacksmithing stuff. It has a garage door, so that will help a lot with the heat involved. But it's also a storage area for garden tools, acetylene rig, and all sorts of other stuff I need to get to, hence the need for a portable forge.
Okay, here's a quick pic. The widened stance is great! Wide angle lens makes them look like they really stick out, but they are only 8" out from the cart. I'll never have a problem turning this thing over. In fact, I had to turn it over to fasten the wiring from the fan to the switch on the underside of the cart's top tray and it was almost a comical feat! Now it's time to start getting the pipe plumbed from the fan to the plenum.
Stopped by Home Depot today and asked if they had any worn out jackhammer bits..........and if so could I have one. The answer was a curt "NO.................you can't have just one. Take six and I'll let you get out the door!" Doncha jus luv a kidder????? Lifetime supply of Hardy material.
It has to be easily moveable in my situation. I just don't have the room to leave it sitting in the middle of the room. My shop is divided into multiply (hobby) sections and everything has it's place...............though sometimes equipment has to be moved out and into another hobby's space. In the case of the forge, it will be stored against the wall near an overhead door. When I want to use it, the door will be opened and the forge rolled into the opening or maybe even outside under the porch overhang. Just can't use a fixed stand.
I appreciate you suggestions, Frosty, but I've way too much time and energy spent on this cart to scrap it. I've got the fan mounted and the wiring channeled to the front of the cart where the switch is mounted. Holes are all drilled for the stand that extends the height of the forge. The extensions will only be 8". Even though I'm wrapping hazard tape on the extensions, I'm not too worried about it. If it's too much, a saw and relocating holes in the 2x6 can easily shorten it.
I think I've mentioned it before, but the narrow "footprint" of this Harbor Freight cart has me worried, especially after getting an approximate weight of this beast. The width of the footprint from center to center of the wheels is only 11 1/2". I'll have a 12" wide, 145# forge sitting about 5 1/2 feet in the air. This forge setup is going to be way too top heavy. That's just not going to be stable enough for moving around and going over thresholds of doors, etc. I'm headed to the DIY store to pick up a 2x6 to widen the stance of this cart. Think I'll feel a whole lot better. Going to wrap the extensions in hazard tape so no-one will trip over them. If this thing were going to sit in one spot and never be moved, I'd not worry about it, but I don't have the room to do that.
Oh, I know, Glenn and thanks for the suggestion. It's just that I've been there and done that and this time I really don't want to risk messing up my nice new forge...............if I ever get it finished.
I know how to crib, Glenn. Built a 30x30 barn with a doubled 2x12, 30' long ridgepole, 18' in the air by myself. Been there, done that. Just don't want to crib this forge up to eye level. I'll get a friend to help. Believe me, I "pay it forward" enough to ask a favor now and then.
Chris C replied to Mark Ling's topic in Blacksmithing, General Discussion
That's a unique twist. I like'em.
