kerryd changed their profile photo
Mokume from US nickels?
I've done two small billets in the last two days out of quarters. About $5 each. This is after I burned the copper and yellow brass I had into a puddle on the floor of my forge (turns out yellow brass melts about 350 degrees lower than copper). Anyway, making a roll of quarters with aluminum foil for a wrapper and just putting them in a vise worked great. I heated the stack with a spare forge burner and squeezed it more with the vise every time it got up to dull orange. After compressing my stack by about 10-15% I just left it in the vice to cool and in a couple of hours I had a really solid piece. Apparently, you don't need as much heat if you have more continuous pressure.
Feather Damascus
I thought I had it all ground out. I wasted two cutting wheels getting it loose, but that bright spot in the center looks suspiciously like the stainless that the hatchet was made from. That's another piece of dumb luck because I'm told that stainless rarely forge welds outside an oxygen free environment.
Feather Damascus
Despite a major screw up I managed to finish this feather damascus gyuto. 124 layers of 1095 & 1080 with 15n20 in bewteen. Never use a cheap chinese hatchet to make the center cut. I managed to weld this thing into the billet and had to cut it out to continue.
1st Knife Build!!!
Did you build that or are they available commercially? Nevermind, I found the website.....COOL!!!
Kitchen Tools
Beautiful work on all of the above, but that bigger cutting board really is exquisite.
Forged 80CrV2 survival knife with bronze and hybridwood
How do those guards attach? This is the second one I've seen you post and I can't, for the life of me, figure out what holds them together.
My first knife.
You did all that with files? It looks really cool for a first knife, or a twentieth knife for that matter.
Tram cable Damascus
The tram up to pill hill was a big deal in Portland when they finished it. Just being able to say you make knives out of the cable would allow you to sell them to yuppies at Saturday Market for way too much money. They won't have to hold an edge because they'll be wall hangings and coffee table conversation pieces, so 1040 will be just fine all by itself.
Intro with some of my knives
If you have enough ratchet straps you can roll anything into the back of a pickup.
My second Damascus blade
Should have been 57 layers, but I think chasing down an inclusion brought it down to about 50. This is the last time I use a farrier's rasp without grinding it totally flat and smooth, probably the last time I use one period. There IS a learning curve. This is only my 4th attempt at forge welding a billet and my second at anything over three layers. If I stay anal enough about cleaning my steel to keep inclusions out of a 200 layer twisted billet in the future I will count myself lucky. "you don't have to be good if you're lucky".
The vulture in the cabinet
Way beyond my skill level. A truly beautiful and functional work of art.
Upgrading a 6 ton log splitter for hammer
I don't know if a log splitter will move fast enough to become a hammer, but I made attachments for my 25 ton gas splitter that turned it into a functional forge press. I may grind off the fullering & flat tools and make removable dies for it in the future. It's still in the experimental stage, but I've managed a couple pieces each of San Mai and Damascus.
Sourcing steel / SW Washington or Oregon
Talked to him on the phone this morning. Seems like a decent guy.
I was at Metal supermarket in Portland yesterday. They don't stock 15n20, L6, or even 1095 or 1084. He said all he had for high carbon was a little 1070. I'll check out Kelly Cupples, Yakima is closer to me anyway. Thanks Steve. I guess I should explore the forums more.
Thank you sir.
