35 -
I ended up redoing this one... Again. In the meantime, I built a small ammo can forge that's 125 cubic inches. I axed the 3/4" burners I was trying to use, picked up the proper ward fittings to make 1/2" sidearm burners, added another burner in between the two so now its a three burner design. I also tore out all the refractory I used, except the wool, and did that all over again. I'm thinking of using kiln shelving as a floor for protection as well as decreasing over all inner dimensions. It got hot enough as it was, but it wasn't right. I have just a couple of things to do to it before it's ready to fire up again, I'll post follow up pics of that. It's not incredibly long, but it's long. 16" . I don't really need one like this, just felt like building it when I didn't have a full grasp on what I was doing. Now that I do, I'm too stubborn not to see it through. The ammo can forge works great and we've been using it a whole bunch. I imagine we'll still use it the most, but this one will be there in case we need it.
Right you are Frosty. I can't ever seem to leave well enough alone, which is why my old Harley chopper spends as much time on the lift as it does the road, if not more. The huffing is the friction I was worried about undoubtedly, slowing the stream down. That was with solid "baffles" no? Wonder what would happen with, say, a fine metal kitchen strainer cut and shaped into a spiral that fit inside the mixing tube?
My +250lb $50 anvil
AdamTheSaint replied to AdamTheSaint's topic in Anvils, Swage Blocks, and Mandrels
Thanks everyone, it sure beats that railroad track you see sitting on the bottom shelf of the cart underneath the forges. Speaking of the track, thinking about setting that up on its end and grinding out a brazeal style inspired anvil for drawing curves and cutting. -
Guy on Craigslist had some 8.5" round stock drops for sale, picked up a 16" piece weighing over 250 pounds... For $50. Found the stump while walking through the neighborhood sitting out by the curb for heavy garbage pick up the following day, knocked on the door and the lady said I could take it. Thing was about as heavy as the steel drop was. Set the drop into the stump about an inch and a half, set it with gorilla wood glue. It ain't going ANYWHERE. Good score I think.
You're two steps ahead of me Frosty, I came to that exact conclusion, came to post it, and you had just typed your last response. I'm gonna go look at my torch pile in the garage now.
When I said pool, I was speaking of "k style " baffles, which are an older design that Hiram Maxam (the patented inventor of the gun silencer, and the car muffler as it were) used in his original design. I apologize for not specifying that. That baffle system is a series of stacked cones with a hole through the very center which allows the projectile to pass through, and also the gasses to move from one chamber to the other, slowing the explosive gas and mixing it with a colder and contained atmosphere. I now remember reading that you had tried steel wool already, so I'll disregard that idea as useless.
Wait a moment... How would packing the mixing tube with stainless wool fair?
That makes total sense actually, I wasn't even thinking of a ribbon burner when I posted that, much less the NARB. Exciting times. K style baffles might work, but I am somewhat concerned about pooling of propane in the tube. Monolith style baffles should alleviate this.
It feels as though a conflict of personalities has the potential to stalemate what could be a good idea. This reminds me of another industry of which I've invested a large amount of time and money, the firearms industry, more so specifically, the SUPPRESSOR industry. Before any anti gunner rolls their eyes, hear me out. Suppressors, or silencers as their patent is actually called, use baffles of various sorts to expand, slow down, and cool off, explosive gases before they're launched into the outside atmosphere, which is part of which makes gunshots non hearing safe. The other being the action of the firearm, and the sonic crack of the projectile breaking the sound barrier, neither of which the silencer can help... But I digress, back to slowing down fast moving gases, and the mixing effect there of, inside of a tube, or pipe, or whatever other semantics you prefer... I'm going to go look at a few of mine now, and while I'm not going to risk destroying something that cost me a lot of money, a $200 tax stamp and registration there of to the BATFE, I actually don't think it would be hard to create a baffle system that would mix the gasses completely, but I do feel this would be best suited for a forced air system, it WILL slow down the velocity of gasses, and a hunch tells me that's counter productive to NA burners.
70 is way, way, WAY high. Like, 10 times too high.
Ok, so mini side arm burner, 2" inswool, 1/4" hymor castable refractory, 1/4" plistex. Seems to work well. Ammo can gets hot but nothing to be alarmed about. Questions, comments, concerns?
3D printed plastic burner experiments (photo heavy)
AdamTheSaint replied to Another FrankenBurner's topic in Gas Forges
Wow. Take my money. Please.- 867 replies
Looking good.
