Everything posted by mpc
Buy or Pass?
Where are you in E. WA? t seems like it’s easier to find stuff like this up in the panhandle and in E.WA. Yesterday I saw a listing for a vice in Troy, ID for $75. I was thinking about reaching out to a prof from law school (who lives in Troy) and seeing if he’d pick it up and hold it for me. Then I’d have an excuse to drive up there for a weekend. Man I miss the Palouse. I think I’m going to offer $100 and politely inform them that they’re way above market rate for something used.
- Can I save my anvil base?
- It won’t forge weld
It won’t forge weld
It’s a 3 burner propane. I don’t know how old the lining is, what it may have been treated with, or how thick it was (originally). I’ve been futzing with the intakes, putting bricks in front of the door, and stuff to get it hotter but I’m basically just taking stabs in the dark. I didn’t build the forge, I got it for a song from some kid who was moving. I want to pull out the liner and do the insulation again but I never seem to have time to chase that pig.
This is my anvil and base. The base is a big ol’ pine log. Pine was not my first choice (or 2nd or 3rd) but when you live in an area with no trees, you take what you can get. As expected, the log is splitting. I’m wondering if it would be worth it to try to forge some straps to go around the log to keep it together. How would you go about forging such a thing? I was thinking I’d put a 90° bend about an inch from each end of a long piece of 1” wide weld steel, drill holes in the 1” tabs, bang the weld steel to shape right on the log, then tighten it down with a bolt through the holes.
It won’t forge weld
This was cleaned up REALLY well, placed in the forge and heated to a dark red, fluxed (Borax), heated more, fluxed again, then left to heat until it looked (to me) like a bright yellow. Then I banged on it enough to make sure both sides were making good contact. I let it cool to black, then I put it in some water (so I could touch it), ground the edges to see how it looked, and then tested it by banging a screwdriver into the V to see how quick it would split. I’ve had a pistachio give me more trouble coming apart than this.
Spring Fuller From Huge Tent Stake
Thanks! What do you think, thin it out to about 1/2 of that?
We’ll see if it works. I’m guessing it’s going to jump out of the hardy hole but it was a learning experience.
- Buy or Pass?
Buy a 4” Post Vice that needs a spring for $100
The title says it all. I saw a listing for a 4” post vice thats in decent shape but needs a spring. I’ve never looked into post vices so but the price is well below what I normally see. Assuming everything but needing a new spring is fine, is it a “buy” at $100?
Question about HT with a pipe
Hmmm... I wonder how long it would take to cook a brat in my forge. It would certainly make it smell a little better.
I came here to ask a similar question. Does anybody have an opinion on wall thickness of the pipe?
Variable Speed Bench Grinder + Coote or Kalamazoo?
Upon closer review, the “1 hp” motor is actually only pushing out 3/4 hp if you’re running on 110. From the OBM website:: The VFD is wired for 110V so the motor produces 3/4hp at 3600rpm which is ample for knife grinding but it can also be rewired for 220V if you wish for the motor to produce 1hp (original instructions for the VFD enclosed).
On both the OBM and Pheer websites they list the 2 hp motor as only getting 1.5 if you’re running on 110. As an aside... Why do some folks refer to 120 and others 110? In the USA they are often used interchangeably in informal conversation but I live out west and it has always been 110 or 220 out here. Is it still 120 in some places?
I have a question about the jump from 1 hp to 1.5 hp. Both Pheer and OBM sell a 1 hp setup with a VFD and a 1.5 hp setup. I’m thinking of just getting an OBM but I want to know how big of a difference I’ll see if I just get the 1 hp with the KBAC-24.
I am in the US (Idaho). I’m specifically wondering if I’d have trouble running something like a Kalamazoo 2FS (2x48)
I have an idea and I’m wondering if it will work. I have access to a variable speed bench grinder (5 amp Delta). Is there any reason I couldn’t slap a pulley for a v belt on that sucker and use it to run a Coote, Kalamazoo, or a Grizzly?
- New Forge
New Forge
I emailed the guy who sold it to me. It is not rigidized. I’ll have to buy some and get on that.
New Forge
It was a DIY by a guy in Utah. I didn’t buy the anvil. I’ve got a chunk of RR track for now. This is gonna’ sound dumb but, how can you tell if it’s rigidized? How “rigid” will it be? I’ll post more photos later. I’ve been too busy keeping the criminals out of jail (day job) to have time to play.
New Forge
So... I was going to build a forge and had the stuff to make some t-burners but a deal popped up on a classified page that got me a working forge, 2 propane tanks, & the reg for less than the sum of the parts. Suggestions for evaluation and tuning of a new forge?
Buy or No Buy?
1st post ever. I’ve been lurking on the board for a while gathering info on burners, grinders, etc... This anvil popped up on a local buy/sell page and I’m thinking of picking it up. All I know is the approximate weight (200 lbs) and the price $450. What (if anything) can anybody tell me from the photos?
